BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Speculation about all the other ECUs NEW TOPIC NEW POLL POST REPLY
ridgeracer
posted May 26, 2006 06:32 AM
The other ECU thread was getting off topic and a lot of people are asking about the other ECUs So I thought I would start a new thread to keep the first one a little more on topic.
Apparently the word on the street is the old ZX-12r ECU was a 16 bit and the newer ones are 32 bit. I posted a comparison of ECU part numbers on the other thread
year 12r ecu
2000 21175-1069
2001 21175-1079
2002 21175-1089
2003 21175-1089
2004 21175-0038
2005 21175-0038
2003 6r 21175-0001
10r 21175-0029
All ECUs for all bikes are 21175-
The first injected 6r is -0001 All the ECUs for ALL the bikes are now -00xx As an engineer it sure looks to me like they came out with a new model ECU right around the time the ZX-12 got the 32 bit. Also as an engineer if I were designing a new ECU for the 6r and I knew I had the 10r, 12r and new 14r in the pipeline I would design one ECU for all with different software. I would not pay Denso to develope me 4 seperate new designs.
I would bet they are all the same inside. Also why have four seperate ways to program them? I bet if you crack one you crack them all.
NEXT ITEM
How different are the 6r 10r kit ECUs from the stock ones? Are they similar enough inside that you could grab the code out of one kit ecu and flash it into a stock ecu and make it into a kit ecu?
WILD SPECULATION
IF the 6r 10r 12r 14r are really all the same ECU
AND IF you can use Kit ECU code to turn a stock ecu into a kit ECU
COULD you create a hybrid KIT 14r or 12r ECU that would use the nice friendly Kawi PC software?
Homework Assignment:
Someone with access to a dealership or all of you with newer manuals together need to get the pinouts and terminal assignments for all the 2006 6r,10r,12r, and 14r ECUs
Also the pinout terminal assignments for the 6r, 10r KIT ECU or A pinout of the kit wire harness.
pin 1 of bike side goes to pin 3 of kit ecu etc. etc.
Plus list any extra wires and where they go.
If they all have a standardized pinout for the injectors, coils, TPS, etc and few unique wires for each model than it would be worth pursuing.
vozizm
Got Nothing Witty To Say
posted May 26, 2006 06:54 AM
Tell you what....
YOU GUYS ARE TRULY AMAZING!!!
VOZ
posted May 26, 2006 07:02 AM
well, this would become a whole lot easier if a few of our tight-lipped buddies at KMC would post the pin-outs...
vozizm
posted May 26, 2006 07:04 AM
or pm them to someone ,,
VOZ
ridgeracer
posted May 26, 2006 07:51 AM
Well at $75 a pop the shop manuals arn't cheap
deathpulse
posted May 26, 2006 09:31 AM
I can buy a shop manual - maybe THAT is how I can help Ridge - which one do you need?
ridgeracer
posted May 26, 2006 10:18 AM
Ah All of them
2005 6r
2005 10r
2005 12r
2006 14r (when they become available)
I would hate to see you spend all that money so I can look at two pages in each manual. Surely we can find one guy with a 6r, another with a 10r and another with a 12r who have manuals to copy the pages for us.
deathpulse
posted May 26, 2006 11:10 AM
Ok - I'll hold a bit and see who coughs em up . If we are missing one, I can fill in though.
supra5677
posted May 26, 2006 11:23 AM
I got a buddy who works at the dealer on saturday's. I'm sure he'd let me borrow them for a while, while I run and go make some copies... I can at least try.. I don't have a scanner though so Id'e have to mail them..
supra5677
posted May 26, 2006 12:10 PM
2006 zx10r 21175-0082/0083 CA
2006 zx6rr 21175-0066
2006 zx14 21175-0084/0089
2005 zx12r 21175-0038
GUNNER
posted May 26, 2006 03:24 PM
I have an 05......10R, and 05........6R shop manual. What do you need from them?
ridgeracer
posted May 26, 2006 04:16 PM
The pin out diagram and terminal assignment list from the chapter on the DFI for the 2005 models
In my 2001 zx-12r manual they look like this
five 0
posted May 26, 2006 04:59 PM
The 2000 thru 2003 are going to be the same bit size I would think. The 04 and newer may be 32 bit.
The 04 and newer have dual butterflies in the throttle bodies and also the ignition rotor has more tits on it. If that makes any since!!!
5-0
GUNNER
posted May 26, 2006 05:13 PM
I'll see if I can get a picture of that and e-mail it to you or photo copy and fax it.
aughtsix
posted May 26, 2006 06:16 PM
Ah, you mean the make-believe KMC reps who are down at the bar drinking with Harvey the 6' tall pink rabbit...
aughtsix
posted May 26, 2006 06:21 PM
Ridge - To give you an idea of my level of expertise, I'm proud that I can make the clock stop blinking on the new DVD player...
But I think you may be on to something because I was wondering how (I think it was Schnitz??) could get a 10r PCIII to work with the new 14. Apparently, they're close enough from the git go.
Keep up the good work and have the white paper on my desk by Monday morning.
blubyu
posted May 27, 2006 05:52 AM        Edited By: blubyu on 27 May 2006 06:53
ECU's
Is there anythings that we lowlifes with the 2002-2003 16 bit processors can do to help? We don't want be left on earth while the 32bit people get to move on to another life!!
deathpulse
posted May 27, 2006 06:03 AM
Don't worry Blu - I think he's workin on the 16-bit .
navpreet318
one crazy 12
posted May 28, 2006 09:21 PM
here you go my friend....hope this helps...
and can you also look in to some similarities in the b3 ECU....
i don't have the option right now otherwise i would have donated you my ECU.....
lets see if i find an ECU here i'll definitely help you out.....
if you need anything else from the b1/b2/b3 manual let me know...will be happy to help you out....
ps.sorry for the extra large pics......mods scale them if you want
2005 ZX-12R,Arata Full Ti, PC3,Gillis
Rearsets,Muzzy Velocity Stacks,BMC
Race filters.One Crazy 12
Two Wheel Werkz
posted September 08, 2011 08:15 AM
does anyone know if a ECU out of a 02 will work in a 02 ZX-12r
so basically will a 21175-1089 work where a 21175-1079 came out of?
shiphteey
posted September 08, 2011 12:29 PM
The 1089 according to ronayers fits 02+ models. The 1079 doesn't come up fitting anything...might be the 1089 is a newer (supercession) one?
A.
Gemini Motorcycles
almost_les
posted September 08, 2011 05:58 PM
the -1089 will fit 02 and 03. those years are identical aside from the paint.
JohnD
posted September 09, 2011 04:53 AM
Ridgercer,
If you need the ZX-12R service manual, Garth285 has posted them here for download. Just see his thread "ZX12 Service Manuals" at the bottom of page 1.
Two Wheel Werkz
posted September 09, 2011 09:45 AM
I am sorry I just realized I screwed up the first post.
the 21175-1079 came out of the 01 zx12 and need to know if the 21175-1089 out of an 02 will work in the 01 bike.
2000redrocket
posted September 17, 2011 03:25 PM
i think ridge said that the 01 to 03 are the same except for software. look it up in the huge post. get popcorn though.
0.25134086608887 seconds processing time
