BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Brake Fluid Question NEW TOPIC NEW POLL POST REPLY
Eric00zx12r
posted April 16, 2002 06:23 AM
Has anyone else tried this yet? Motul 5.1 Fluid
Dealer had it for little over $6.00 a bottle. Says it's compatible with DOT 3 & 4. Figured while I was switching brake lines I'd try something new and hopefully superior.
http://www.motul.com/uk/produits/index.html
Blurb from their website.
Dot 5.1 brake fluid
LONG LIFE 100% synthetic fluid for hydraulic actuated-brake and clutch systems.
DOT 5.1 NON-SILICONE BASE.
Fluidity specially designed for anti-locking brake systems.
LONG LIFE FORMULA : the high wet boiling point (185°c/365°F), superior to DOT 4 and DOT 3 fluids enables to use this product longer.
SPECIALLY DESIGNED TO ANTI-LOCKING BRAKE SYSTEM (ABS) : its viscosity (820 centipoises at -40°c / -40°F) lower than DOT 4 and DOT 3 brake fluids, allows MOTUL BRAKE FLUID DOT 5.1 an easier fluid circulation in micro-valves of anti-locking systems.
PERFECTLY NEUTRAL WITH SEALS USED IN BRAKING SYSTEMS. ANTI-CORROSION.
Eric
00ZX-12R
Candy Persimmon Red
WhiteLightning
posted April 16, 2002 07:39 AM
Stupid
Well, this naming convention makes no sense!
I love 5.1 stuff. Its great. Only two brake fluids I'll use. Motul600 or the Bel-Ray 5.1
I think most manufacturers are too afraid to call thier stuff 5.1 Thus they call it 3 race.
Go look up the specs... 5.1 sounds great.
How do you rate brake fluid? It never gave me a problem. 5.1 seemed to last a bit longer then my Motul (I like to change Motul at least once a year if not twice).
WL
psycho1122
posted April 16, 2002 07:45 AM
Castrol GTX-LMA....Best stuff I've Ever used.
posted April 17, 2002 03:43 AM
And $2.39 a bottle at the auto parts store!!
Just did 4 bikes with one bottle.
Brake fluid is inexpenisve enough to change it often .
12RPilot
posted April 17, 2002 05:17 AM
Oh Yeah? Well I use mercury in my brakes. Totally uncompressable and not broken down by heat. In fact, it draws heat away from the brakes so fast they actually run 200 degrees cooler. And the extra couple of pounds up front helps keep the front end down. Of course if I wreck the whole area becomes a hazardous waste site and the road must be closed to pets and toddlers. Hey, there's always a down side.
NESBA #209
0.24098896980286 seconds processing time
