BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Gear Sensor NEW TOPIC NEW POLL POST REPLY
bluemoss
posted May 19, 2006 11:26 AM
Gear Sensor
How would one get to, remove or disconnect to clean gear sensor? My neutral light sometimes work and sometimes it dosen't. I've heard it could be the gear sensor going out or just need cleaning because it get's pretty filthy over time.
droid
posted May 19, 2006 12:42 PM        Edited By: droid on 19 May 2006 13:47
L/H side behind/below sprocket cover, 2 crosshead screws,gently pry out ,casing is only hard plastic. Beware of spring and brass contactor in gear selector drum, shouldn't fly out just be aware!
Make sure you lube seal on reassembly other wise you risk cracking sensor casing.
There is a ground wire onto one of the screws i think could be dirty connection
BTW did you manage to get manual??
bluemoss
posted May 19, 2006 07:03 PM
Yep, I have the manual, but it doesn't state how to remove or get to unit.
Ok, I'll try locating it from your instructions and using the manual.
0.30888605117798 seconds processing time
