BIKELAND > FORUMS > ZX12R ZONE.com > Thread: clutch setting NEW TOPIC NEW POLL POST REPLY
fast
posted April 14, 2002 07:23 AM
clutch setting
Do any one know a way to make the clutch
grab closer to the grip?Can i do something
in the clutch(plates?)or there is only
the setting on the lever!!!
THANKS!!!
9.29@151
eric00zx12r
posted April 14, 2002 08:26 AM
simply adjust your cable either at the lever or at the clutch housing. At the lever, just start turning your adjuster one way or the other and just see where you like it. Make sure to leave a little bit of "play" in the lever so you don't burn up the clutch plates.
I like to set my lever adjuster to a specific positon then get my fine tuning at the clutch housing. I leave about 3 threads showing at the lever and make the adjustments at the housing.
It's easier to do it a the lever cause you simply move the adjuster. At the housing, you have to loosen two nuts and rotate the adjuster up or down depending on where you want it to go.
Hope this helps and doesn't confuse you more
Eric
00ZX-12R
Candy Persimmon Red
0.2444589138031 seconds processing time
