BIKELAND > FORUMS > ZX12R ZONE.com > Thread: tire pressure NEW TOPIC NEW POLL POST REPLY
TripodMeat
posted April 12, 2002 06:33 PM        Edited By: TripodMeat on 12 Apr 2002 19:50
Tire pressure
This has probably been posted before, but here it is anyway:
What do y'all run your tire pressure at ???
( I have my original D207's..I am at 35, max says 41 )
a ref to a previous thread would work, too
ZXtra
posted April 12, 2002 06:54 PM
39 LBS. front and rear.
Are you getting any scallopping on the front at 35 LBS.? -ZXtra
TripodMeat
posted April 12, 2002 08:02 PM
define scalloping, if you will.....
also wondering if the higher pressure will reduce the life-span of the tire?
EastBayDave
posted April 13, 2002 06:10 AM
Dunflop D207ZR "RR"
36 front, 38 rear. Couple of PSI lower on very cold days...works good.
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
kawachan
posted April 13, 2002 06:39 AM
define scalloping, if you will.....?
Scalloping A brand new tire is perfectly round, but when tire pressure is low, sometimes the tire will start wearing funny. You can feel it by running your hand along the length of the tire tread. Tire will no longer have a smooth contour and will be very "bumpy". Usually the front edge of the tire tread will be slighly higher than the rest of the tread. After it gets worse, a small lip may occur on the edges of the tread as the rubber is being peeled off. Time to replace tire.......
RED NINJAS RULE!!
psycho1122
posted April 15, 2002 11:49 AM
BT010's ...31 front/ 33 rear, go up 1 maybe 2 lb. on hot pavement in summer.
0.21520113945007 seconds processing time
