BIKELAND > FORUMS > ZX12R ZONE.com > Thread: ZRX damage... NEW TOPIC NEW POLL POST REPLY
ZRXDean
posted April 12, 2002 09:10 AM
ZRX damage...
Last weekend at Prostar I dropped a valve in the 3rd round. An exhaust valve broke off at the head and punched a hole in the piston. The cylinder just got sent to Superbike Mike to be resleeved, and my new 1mm oversize Ferreas just arrived today. The head will go to George Babor in Clearwater Monday to be fixed up and cut for big valves. While that's being done Kevin & I will probably split the cases and check the bearings. If the stars are aligned and Buddha smiles on me I'll make the next SEMDRA race April 27th. We shall see.
Sorry for the small cropped ppic, I was trying to make it easily email-able.
Dean
madmike
posted April 12, 2002 10:42 AM
oh man dean damn!!! that sucks, but hope the bearings and all are ok!! good luck on getting everything ready!
Mad Mike
RAC4IT
Bergie
posted April 12, 2002 04:19 PM
damn!
that sucks! keep us posted once you get it torn down.
frEEk
posted April 12, 2002 06:29 PM
geez, u can actually fix that?!? looks wasted!
krexken
posted April 12, 2002 08:43 PM
Ouch. I know they don't give those valves away. I'll bet your bottom end is fine. Mike's still got my block too. I'm ready for it! Gonna keep using the same springs? How'd the one cam work out for ya?
ZRXDean
posted April 12, 2002 10:14 PM
Thanks for the empathy guys. I decided to look at it as an opportunity to go faster..took me about 1/2 hour
The valves weren't too too bad, $14 straight from Ferrea. I'm gonna try to check the suspect rod bearings with the cases together, and save myself some hassle, I'm thinking things are OK. Since I can't seem to get George to answer the phone or call me back, it looks like Greg Cope will do the head, and set my spring pressure if needed. I hadn't tried the intake cam yet, and won't until I get a new baseline with the big valves I guess. Think I can break into the 20s on motor? Hee hee. Lofty goals.
Dean
jessz1
Half the wheels, twice the fun
posted April 13, 2002 05:29 AM
Damn!! Count yourself lucky, A dropped valve can easily destroy the whole engine. Good luck with the new ones!! 20's shouldn't be a problem, that Zrex is badass!!!!
I'm never satisfied.
  Ignore this member    Click here to send jessz1 an AIM message.
EastBayDave
posted April 13, 2002 05:56 AM
Damn Dean! Sorry to hear of the misfortune. Well that gives you an excuse to make it faster! What was the cause of the valve breaking off? Were they stockers or aftermarket? Also can you give any info on the "Ferrea" replacements? Never heard of them...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
harryzx-12
posted April 13, 2002 09:25 AM
Bad luck Dean
Hope everything is ok with the bottom end.At least you will have an even better motor when you are done.
ZRXDean
posted April 13, 2002 10:25 AM
The valves were stock, and I guess it's not too unususal for stock valves to break. I have APE springs, and never rev it past 11Krpm, so theoretically they should never break, but I guess this exhaust valve skipped that class. I do count myself lucky, it could've been much worse. I'm told that in the 'old days' that it was standard procedure to install stainless valves on a built motor.
Ferrea makes the best stainless and titanium valves out there for motorcycles, cars too I guess. Everybody I talked to swears by them. This will be my first set. http://www.ferrea.com/ They're in South Florida, so they got here in one day - real purty. $250 total with shipping & tax.
Tonite I'll drop the pan and find the chunk of piston, hopefully sitting peacefully at the bottom, with nice sharp edges. I went out last night, had a few Guinness, but I kept thinking about a little chunk of aluminum bouncing around the crank. Hi, I'm Dean, and I'm a accelloholic.
Dean
0.24488306045532 seconds processing time
