BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Fuel Injection Stumble NEW TOPIC NEW POLL POST REPLY
go-t
posted May 06, 2006 01:26 PM        Edited By: go-t on 6 May 2006 14:26
Greetings All - Hope your season has started off well.
I have a 2001 A2 with 38,000 kms on it. Every now and then the fuel injection light comes on for a split second cuts out and then resumes like nothing has happened. No rhyme or reason for it.
Has anyone had this problem and what was it.
Thaks very much.
My girlfriend can't wrestle but you should see her box
Kwaka12
posted May 07, 2006 12:10 AM
do you have powercommander ?
since i have added some advance , especially at low revs with medium and higher throttle positions, the problem has disappeared.
i have also lowered the gearing.
Wildman
I only look confused
posted May 07, 2006 05:58 PM
Get a manual and check the fault code(s).
Done by grounding a certain wire and counting the long and short flashes.
If you build something Idiot Proof, The world will build a better Idiot.
flite leader
posted May 08, 2006 10:53 AM
some time ago several people had a similar problem
........TPI
throttle position sensor
some were moved........guys tryin crap[
some moved anyway.... screws & vibrations
& a few just bit the dust
set at the factory.....NOT a hit or miss situation
could be your problem
good luck
bend your mind.....
or break your ass...!!
0.24377822875977 seconds processing time
