BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Tach problem, any ideas? NEW TOPIC NEW POLL POST REPLY
Scooter
posted April 29, 2006 03:20 PM
Here's the scoop. I changed out the guage faces for white ones and now my tach reads low. It's showing about half what it should. 70 mph reads about 3K. Idle 400 when I know it's around 1K. Ran it up to rev limiter in 1st and that appears correct, just above redline. Span is good but zero is off. Both needles zero out right together when you turn the ignition on so I dont think the needle is dragging. Maybe I pushed it on too far? I was careful not to create any static discharge when I had 'em apart. Battery is new also. Anybody else ever have this happen. FIgured I ask before I go diggin in.
  Ignore this member    Click here to visit Scooter's homepage.
posted April 29, 2006 04:44 PM
What two years tachs did you swap?
Scooter
posted April 29, 2006 08:17 PM        Edited By: Scooter on 29 Apr 2006 21:19
Not a swap, just disassembled the original cluster and changed out the faceplates. It's a 2000 if that matters. I am the original owner.
After some searching I found the link. Looks like I may need to pull the needle and reposition it. Didn't think it would be necessary since the guages appear to reset upon powering up. They do return to zero when the motor is off.
http://www.sportbikeeffects.com/info/ZX-12R_gauge_inst.htm
aliveagain
posted April 30, 2006 06:10 PM
Any luck yet? I think first I would double check all the connections that were involved.Then I would try advancing the tach needle 400-500rpms and see if it still zeroes out.
Scooter
posted April 30, 2006 10:14 PM
Fiddled with it a bit and and decided to do just that. Dissassembled and pulled the needle, rezeroed(cycley power) with no needle then buttoned it back up. Was 11PM and raining so I didn't get to ride it but appears OK now. We'll see when I get to ride the thing. Thanks all.
0.22715020179749 seconds processing time
