BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Shimming the clutch stack... NEW TOPIC NEW POLL POST REPLY
Y2KZX12R
CompetitionCNC.com
posted April 12, 2006 05:37 AM
Have any of you guys tried adding an extra 1.6 mm steel to the stack to increase the stack height?
Does anyone make a thicker steel than a 2.0mm?
Y2KZX12R
CompetitionCNC.com
rac4it
Bergie
posted April 12, 2006 07:10 AM
I do it all the time.
Sometimes you need to add a 2nd 1.6 steel in the pack to get the height correct after wear. I do this with the Muzzys pack a lot or just when I typically use all 2.0 steels, I'll add a 1.6 after some time to get it stacked up again.
Although the title of this topic should be stacking steels not shimming. Shimming normally refers to adding washers to the spring pack to tighten up the pressure on the stack.
Y2KZX12R
CompetitionCNC.com
posted April 12, 2006 07:49 AM        Edited By: Y2KZX12R on 12 Apr 2006 08:50
No warpage issues with two steels together?
I'm thinking this is why the clutch is slipping. I have the muzzy kit and all the frictions and steels are still sweet but i just needed some stack height even thou the cover wasnt bottoming out.
I have the schnitz springs anyway, but i'll bet its better now with a 1.6 in there.
thanks
Y2KZX12R
CompetitionCNC.com
your car is slow
Fuck Nitrous...Got Boost?
posted April 12, 2006 09:42 AM
nah..the steels dont friction against each other...they turn in the same direction...its like making one big 3.6mm steel.
posted April 12, 2006 10:54 AM
I also use 2 - 1.6 to make a 3.2. I even have a few 1.4 for this purpose. If not high enough you can ruin a few Pullers!
rac4it
Bergie
posted April 12, 2006 12:48 PM
No the plates dont warp, because like Brian and Vincent said, they dont spin against each other, they are stacked locked together and create a virtual single plate. I think everyone with drag experience on a ZX12 does this.
Y2KZX12R
CompetitionCNC.com
posted April 12, 2006 05:22 PM
Right, I know they dont spin against each other, but was concerned if two steels disapate the heat the same as the other 2.0s or can they buckle away from each other when hot type thing and cause a change in clutch feal when hot and cold.
Thanks guys.
ninja12
posted April 13, 2006 06:24 AM
When you consider the options, even IF it did warp you don't have much choice.
I have used the 1.4s and 1.6s to increase stack, never noticed any increased wear or warpage.
posted April 13, 2006 07:56 AM
Thanks guys.
Remember they are touching and having heat transfer berween them and the Oil acts as part of the conductoras opposed to an insulator
0.24726700782776 seconds processing time
