BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 12r&hesitation problems? NEW TOPIC NEW POLL POST REPLY
mach111
posted April 05, 2002 04:41 PM        Edited By: mach111 on 5 Apr 2002 17:00
12R&HESITATION PROBLEMS?
ANYBODY OUT THERE EXPERIENCE HESITATION PROBLEMS AND SPUTTERING FROM 1-4K.R.P.M.'S?MINE IS.PROBLEM JUST STARTED.FIST THING I WILL CHECK IS THE P.C111R, TO SEE IF IT IS WORKING PROPERLY. I SENT IT BACK TODAY .THEY ARE PRETTY GOOD HONORING WARRANTY WORK.IF MY BIKE IS PIPED AND THE P.C IS NOT WORKING THAT CAN CAUSE HESITATION AND SPUTTERING ON LOW R.P.M , THAT'S WHAT PHIL AT D.J SAID.OR IT CAN BE A CLOGGED FUEL INJECTOR THOUGH IT DOES IDLE FINE & RUN GOOD AFTER 3K.R.P.M'S.I ALSO TRIED GETTING THE F.I SYNC'D,THEY WERE OFF BUT IT DID NOT CURE THE HESITATION PROBLEM. BUT BOY DID THAT GIVE ME QUICKER THROTTLE RESPONCE AFTER 3K.AND I CAN'T EVEN GO INTO THOSE 1ST&2ND GEAR WHEELIES.I WOULD HIGHLY RECOMEND GETTING THIS DONE IF YOU THINK IT'S OFF.
ANYBODY ELSE HAVE ANY OTHER IDEA'S ON WHAT ELSE TO CHECK ABOUT THE HESITATION AND SPUTTERING BELOW 1K ON TAKE-OFF.
I'M TIRED OF TACHING IT UP ON TAKEOFF,AND RUNNING BAD JUST CRUISIN IN TOWN.I HEARD SOME OF THESE 12'S DO HAVE A HESITATION PROBLEM,BUT SOME FRIENDS AND I WHO HAVE 12'S SWITCHED BIKES AND EVERYBODY AGREED I HAVE A PROBLEM.I SHOULD TAKE IT TO KAWI UNDER MY G.T.P.P..
harryzx-12
posted April 05, 2002 04:44 PM
Kill the fuckin caps dude
Since when did ZX-12's have carbs? Mines fuel injected.
slug
Out in search of my mind...
posted April 05, 2002 05:15 PM
i read that thing 4 times trying to find where he said carbs...
finally saw that it was edited after post hehehehee
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
Phil
posted April 05, 2002 07:04 PM
The throttle bodies can be syncronized or balanced ??? Does the shop manual give details for this?
posted April 05, 2002 07:08 PM
We need a little more info....
do you have the pipe/ pc3? If so you should make sure that your TPS is in its stock/ factory setting, and then the TPS further adjusted correctly through the PC3.. if this is not done, the fuel table will not be mapped correctly to your bike.
mach111
posted April 05, 2002 08:33 PM        Edited By: mach111 on 5 Apr 2002 20:33
WHAT'S THIS ABOUT CARBS?I DIDN'T SAY ANYTHING ABOUT CARBS.i RE-EDITED TO ADD SOME MORE INPUT.I WOULD NEVER MAKE A MISTAKE ON MY 12 THAN GO BACK IN AND CORRECT IT NEVER.
I DO HAVE A FULL MUZZY AND P.C111R.T.PS. IS SET TO 1.085..
WARRANTY HERE I COME...................................>>>>>>
harryzx-12
posted April 06, 2002 05:12 AM
You're a fuckin LIAR
I was just razzin you about you saying carbs and you did say carbs (I knew you meant to say injectors). I'm not much on liars.Good luck on fixing your problem and KILL THE FUCKIN CAPS!
Ninjaman12R
as a Deal's Gap tour guide.
posted April 06, 2002 08:10 AM
Harry......
Such a softspoken and gentle soul. If everyone could be as passive as you what a wonderful world it would be.
NOW SHUT THE FUCK UP YOU GODDAMNED SHIT EATIN', NO GOOD FOR NOTHIN ,PECKER PUFFIN, ROOT WRANGLIN', ASS LICKIN', TRUCK STOP QUEENIE BIATCH!!!!!
IF YOU TELL ME TO KILL THE CAPS I'LL DRIVE TO FLORIDA AND PUT MY FOOT IN YOUR ASS!!!!
Oh yeah,....it was good talkin' to you the other night.
harryzx-12
posted April 06, 2002 08:41 AM
Kill the caps NinjaFuck!
Fuck you too Ninjaboy, president of the tennesse turd burgulars association.
Ninjaman12R
posted April 06, 2002 10:49 AM        Edited By: Ninjaman12R on 6 Apr 2002 10:49
YOU FUCKIN' KNOB GOBBLER.....
Harry I'd hate to see you going into the ER looking like a fuckin' popsicle with my leg sticking out of your ass.
Your Car Is Slow
Fuck Nitrous...Got Boost?
posted April 06, 2002 11:18 AM
You two have a lot of built up sexual frustration
Do not taunt happy fun ball!
posted April 06, 2002 06:22 PM
But it does sound like they've gotten to know each other in a close, meaningful way.
harryzx-12
posted April 06, 2002 08:32 PM
Up your nose
With a big rubber hose larry!
kzz1
"Show me whatcha workin with"
posted April 07, 2002 04:51 AM
Yes you can and yes you should check them. I check my bikes with mercury filled syncro. gauges. Helps with the idle and off idle throttle response.
mach111
posted April 11, 2002 02:51 AM
problem solved
My p.c111r was bad after all.Got a call from d.j & a new one is on the way blue label.Great warranty from d.j. as long as the unit is broken from natural causes.A new one with "all the bugs taken care of from past problems with the p.c111r and 12r is going to make me a happy camper.
I knew the bike seemed to run crappy like it did with my exhaust on it before my p.c arrived.I wonder what "bugs" dynojet worked out with the p.c?They told me they had been having problems with some of the 12's with only the p.c.111r.
harryzx-12
posted April 11, 2002 03:37 AM
Glad you got it fixed
And thanks for killin the caps!
ROCKET J
Goes to water over a dummy!!!
posted April 11, 2002 09:22 PM
Unless you hold the brake on...
I think it is physically impossible to get a ZX-12R below 1000 rpm.
Rocket
If I get any smarter, my head will explode!
0.29703307151794 seconds processing time
