BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12 engine swap NEW TOPIC NEW POLL POST REPLY
scott d
posted April 01, 2006 07:24 PM
zx12 engine swap
Trying to find out if a 2001 zx12 motor will work in a 2000 model. Is anything different in the wiring ofr fuel injection? thanks
THEMADKAW
posted April 01, 2006 08:07 PM
'00 and '01 are the same engine.
posted April 01, 2006 09:34 PM
They will not work direct! you will have to change the cam timing sensor on for the model year ECU/Wiring you are using...
Mad Mike
five 0
posted April 02, 2006 06:24 PM
Mike, its not the sensor, its the pickup on the end of the cam!!! Different timing on them!!
5-0
gunner
posted April 02, 2006 06:36 PM
So you can use the proper year cam with the proper year ECU and all is well???
zxboy
posted April 02, 2006 08:49 PM
I helped Scott with the actual motor swap..... he called me a day later after he hooked up all the electric etc... and he couldn't get the motor to fire. I went over and checked it out. It wanted to fire but sounded like the timing was off ???? the plugs were wet and probably fowled. So if I get you right Mad Mike, we'll put the original cam sensor in the new motor and some fresh plugs and should be good.... Thanks for your help and I'll let you guys know what happened. Roy
zxboy
posted April 02, 2006 08:51 PM
Uh Oh.... I just saw five-O's post. Do we have to swap the cam out ???????
posted April 03, 2006 03:32 AM
5-0
yep... you got it.... I was just thinking you could change the sensor....
osti33
posted April 03, 2006 07:08 AM
Not the whole cam. Just the pick-up on the end of the exhaust cam.
zxboy
posted April 03, 2006 10:22 AM
O.K. I've got it..... Thanks for the help !!! Roy
five 0
posted April 05, 2006 06:29 PM
Its the whole cam. The slot in the end is timed different. There is a company now that makes our race cars that is making new pick-ups that are timed different. About a 5 minute fix.
5-0
scott d
posted April 05, 2006 09:05 PM
Changed cam, Started right up. Thanks for all the help. Scott D
osti33
posted April 05, 2006 09:49 PM
5-0
Hmm...Shows what I know. I thought you just had to change the pickup.
ninja12
posted April 06, 2006 07:00 AM
It's easier to move the pick-up than change cams and re-shim.
Either way will work, just how much work do you want to do.
zxboy
posted April 06, 2006 10:26 AM
Yep... Swapped out the cam and it fired up!!!!!
ninja12
posted April 06, 2006 07:54 PM
Did you shim it or just swap and run?
zxboy
posted April 07, 2006 07:02 AM
My buddy (Scott) did the cam swap and I'm sure he just swapped them out. I'll check the clearances this week end. I'll let you know how far out they were.......
ninja12
posted April 07, 2006 12:08 PM
LOL,
I wish you luck, but with 8 valves chances are very good that you will need to make adjustments somewhere.
Take the cam you took out, pull the pickup off and grind the place holder tit off.
Look at the one you put in, and put the sensor on the old cam at the same angle
relation to the last cam lobe. The bolt will hold it tight enough since the is no force on it.
Since you will have to pull the cam to shim. Just put that one in and IF the shims were
right they will still be right. IF you have a shim kit handy eight way is quick and easy.
0.29525399208069 seconds processing time
