Y2KZX12R
CompetitionCNC.com
posted April 01, 2006 01:55 PM
Edited By: Y2KZX12R on 4 Apr 2006 17:19
Clutch shimming......
What springs and shims are you guys running on your 12s.
So far I've been running the Muzzy hub kit that came with three gold springs and reused three stock springs.
Well guess what, It cant hold the 1375 engine at 9000 rpm.
Where are you guys getting shims from and how thick? Also has anyone tried 6 muzzy gold springs?
posted April 01, 2006 03:06 PM
6 muzzy clutch kit springs holds it fine, although i did shim the springs for doing top end "tests".
Y2KZX12R
CompetitionCNC.com
posted April 01, 2006 03:18 PM
Thanks. I'll have to call Muzzys for 3 more.
posted April 01, 2006 08:11 PM
Jim, buy 6 new springs...
posted April 01, 2006 09:37 PM
Where are you guys getting shims from and how thick? Also has anyone tried 3 muzzy gold springs?
The only reason this would not hold, Is your clutch is SMOKED... I have run my 1361 with only 3 muzzy springs and no shims for years with out any issues....
Mad Mike
Y2KZX12R
CompetitionCNC.com
posted April 02, 2006 10:57 AM
I'll have to take it apart and check the clutch over good. Theres no heat issues at all, I do know that. The 2.0 steels look new still.
Mike what frictions do you use? Are Barnet frictions any good in the 12r?
I've never had to replace them yet because the factory covered a set for me.
posted April 02, 2006 11:08 AM
Great on the 2.0 steels!!!
I use stock frictions.
and on Barnett ABSOLUTLY NOT, NEVER EVER USE THEM!!! THEY TOTALLY SUCK!! A COMPLETE WASTE OF $$$.
and I probably would not reccomend them to anyone either...
How do you know the clutch is slipping? can you actually feel it slipping? the reason I am saying this is if it was slipping your steels would "not" look brand new....
Mad Mike
Y2KZX12R
CompetitionCNC.com
posted April 02, 2006 01:25 PM
Edited By: Y2KZX12R on 2 Apr 2006 14:25
Well when your full throttle and the tach sweeps past 9000 rpm the rpms flair up and you have to get off the throttle.
So I took it apart and I measured all the frictions. They are all within the spec of (.127"-.133")Most were .130" and two were .129". The service limit is .100"
The steels are like out of the box new.
Has anyone tried the schnits spring set?
inxs
posted April 03, 2006 03:23 AM
Have you checked the clutch pack assembly length? On my 02 the length was well under the 56.8-57.6 mm spec,even though the plates looked new & measured well---looked like a factory fuck-up.Added some 2.0's to thicken it up.Clutch then worked better than new.1-2 shift was the most noticable differance--very firm shift !
Y2KZX12R
CompetitionCNC.com
posted April 03, 2006 05:19 AM
Edited By: Y2KZX12R on 4 Apr 2006 17:18
Whats the spec on the overall stack height on the muzzy clutch setup?
Y2KZX12R
CompetitionCNC.com
Y2KZX12R
CompetitionCNC.com
posted April 04, 2006 04:18 PM
Anyone ever measure it?
ninja12
posted April 04, 2006 07:48 PM
did you remember not to offset the last fiber?
Y2KZX12R
CompetitionCNC.com
posted April 05, 2006 03:27 AM
Yep.
Y2KZX12R
CompetitionCNC.com
your car is slow
Fuck Nitrous...Got Boost?
posted April 05, 2006 09:49 AM
does the pack stick out at all past the basket fingers?
Id used 6 zx6r springs on mine....it held upto 250hp on spray.
believe the schnitz springs are even beefier than 6r springs.
Y2KZX12R
CompetitionCNC.com
posted April 05, 2006 10:31 AM
Let me think.... if i remember correct the cover sticks out about 2/3 of the 1/8" thickness. If that makes any sence at all to ya.
I ordered the schnitz springs because i needed a crankcase filter anyway. They were 30 bucks.
Y2KZX12R
CompetitionCNC.com
