BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Help adjusting clutch NEW TOPIC NEW POLL POST REPLY
Eric00zx12r
posted March 27, 2002 07:40 AM
after putting the motor back in the bike, today was the first chance I've had to ride. My clutch feels like it's catching in a different place. Feels like it's catching later...with the lever almost all the way out. Before, it cought almost as soon as I started to let it out.
I think the problem is with the "adjuster" at the clutch housing itself. Question is anyone know off had which way to move the adjuster. I'm talking about the end of the cable with the two nuts next to the housing. I'm sure if I move that one way or another it will adjust the "catching" point.
If no one knows...I'll just play with it (keep your minds out of the gutter)
Eric
00ZX-12R
Candy Persimmon Red
posted March 27, 2002 08:34 AM
I am sure you have it adjusted at the lever also?
jessz1
Half the wheels, twice the fun
posted March 27, 2002 08:37 AM
Do you have any free play at the lever? Probibly not. Adjust it so you have a little slop and see if thats better
I'm never satisfied.
  Ignore this member    Click here to send jessz1 an AIM message.
Eric00zx12r
posted March 27, 2002 11:05 AM
hey guys, I've got the proper free play at the lever. Forgot to put that in my post. Sorry. I took a close look at the threads on the lower adjusting point and it looks like I'm about 1/8 to 1/4 down from where I was before. I'll make that correction when I get home. I'm pretty sure that's where the problem lies.
Eric
00ZX-12R
Candy Persimmon Red
jessz1
posted March 27, 2002 11:45 AM
If you have free play at the top it shouldn't matter where the bottom adjustment is at. :scratching head:???
eric00zx12r
posted March 27, 2002 04:03 PM
sorry guys, I just re-read my post. Does make me sound like an idiot. Guess that's what happens when you are at work and trying to fit a simple post in the middle of a busy day.
I had the top adjuster where I wanted it. about 2 threads showing. I just had to move the bottom nuts up a bit to give the the slack I wanted. Yea I could have just adjusted it at the top, and it would probably been easier, but this way I shouldn't have to touch the bottom adjusters for a long time. As needed, I can simply move the top lever adjuster.
Reason for going through this pain in the ass is I've not had to adjust the free play in the cable in almost 12,000 miles. I knew exactly where the top lever adjuster was and I wanted to keep it there. Just helps me gage wear.
Thanks for the input.
Eric
00ZX-12R
Candy Persimmon Red
jessz1
posted March 28, 2002 09:12 AM
I see. Good luck!!
0.26995801925659 seconds processing time
