BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Problem with master cilinder NEW TOPIC NEW POLL POST REPLY
Marcos Peguero
posted March 01, 2006 04:54 AM
My brake master cilynder (nissin 119mm radial) just leaks very slow from the bleeder that is on top of the piston.
My brakes are ok, until I start braking hard, then they just start to fade, then I have to bleed them. I have to use them in #1, because the lever is very soft.
If I take off the caliper, and move the pads I feel that I have to bleed them.
Im thinking of a new master cilinder.
Recomendations?
  Ignore this member    Click here to visit Marcos Peguero's homepage.
wheeliekev
posted March 01, 2006 12:49 PM
i had a similar problem, i changed the master cylinder seal and fitted a new bleed nipple and cured it, best of luck
posted March 01, 2006 01:04 PM
Our Mastercylinder has a Bleeder? I need to look because I do not remember seeing one? I just remember releasing the bolt for the lines!
Marcos Peguero
posted March 02, 2006 02:49 AM
VH, i have a nissin 19mm one radial. the zx12r comes with a axial 16mm one.
kawasabi
posted March 02, 2006 05:07 AM        Edited By: kawasabi on 2 Mar 2006 05:08
You didn't put kool-aid in it, did you?
Marcos Peguero
posted March 02, 2006 06:37 AM
No...
I can see that the bleeder seat is damaged. I ordered a new one and another bleeder bolt (to see if it solves the problem and use that one on the other bike)
0.21768116950989 seconds processing time
