BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Ping Doug Meyer/Rob Muzzy... 05 speed restriction.. NEW TOPIC NEW POLL POST REPLY
zx12richard
The Green Monster..
posted February 17, 2006 06:09 AM
Theres a guy on another site I frequent who wants to remove speed restriction on a 05 ZX12.... Muzzy have any products for it or whats his best bet?????
Thanxxxx in advance to all who answer...
TRNorBRN6001
posted February 17, 2006 07:11 AM
Does the Bonneville Box not work on an 05?
TFA 200MPH CLUB MEMBER!
zx12richard
The Green Monster..
posted February 17, 2006 08:04 AM
What someone was sayin... Not sure myself... Lists on Muzzys site 01-03... Doesn't mention 04 and 05.... So I am just trying to help a brutha out by finding out what I can...
TRNorBRN6001
posted February 17, 2006 08:46 AM
Might just not be updated on the site. Just give Muzzy a call and
talk to one of the tech guys. I did not think things changed for
04-05, but I have an old unrestricted Y2K model. By any chance
might your friend be headed to the Texas Mile for a little flyer fun?
zx12richard
The Green Monster..
posted February 17, 2006 08:55 AM
Maxton.....
zx12richard
The Green Monster..
posted February 17, 2006 09:46 AM
Can't believe nobody knows this fer sure.... Thought this would be an easy one...
RAC4IT
Bergie
posted February 17, 2006 10:44 AM
Are you going to Maxton for the April 1/2 meet? I will be there.
zx12richard
The Green Monster..
posted February 17, 2006 10:54 AM        Edited By: zx12richard on 17 Feb 2006 10:55
Nope would like too someday, Texas is much closer though... I do asphalt work,only way I would get to go there is to repave it.. I have now life when its warm.... LOL
Got any tips for the guy with the 05??? He is wanting to do Maxton so need derestricted.... I am just trying to help him find an answer....
supra5677
posted February 17, 2006 11:02 AM
just extend the rev limit.. sbm@superbikemike.com
your car is slow
Fuck Nitrous...Got Boost?
posted February 17, 2006 11:34 AM
how exactly will extending the rev limit bypass the 186mph restriction?
zx12richard
The Green Monster..
posted February 17, 2006 12:17 PM
+1?????? Specially if its in the speedo system..
posted February 17, 2006 01:05 PM
It won't.
To my knowledge, Muzzys does not have a "Bonneville box" de-restrictor for the 04/95 bikes.
Doug
zx12richard
The Green Monster..
posted February 17, 2006 01:18 PM
Thanxxx Doug... Guess those guys are just slower than the rest forever????LOL
TRNorBRN6001
posted February 17, 2006 01:33 PM
That sucks, surely one of the big guns must know. I wonder if it is a
speed sensor, or gear/rpm modulated limiter. JohnnyCheese might
know as he has a lot of experience with 12's and actually fabricated
a better anti-limiting mod for the Busa.
supra5677
posted February 17, 2006 03:02 PM
the ecm will have to be re programmed to continue to rev passed 11625+/--.
your car is slow
posted February 17, 2006 03:35 PM
zx12richard
The Green Monster..
posted February 17, 2006 03:46 PM
Restriction is speed limited not rpm limited from my understanding....
zx12richard
The Green Monster..
posted February 18, 2006 01:56 PM
Can't believe there is no options for this, a complete territory that nobody has tapped????? Thanxxx..
zrexpilot
posted February 19, 2006 07:15 PM        Edited By: zrexpilot on 19 Feb 2006 19:17
It won't.
Doug
any plans to make one ?
and how is the 04-05 12 restricted, is it from the speed sensor, or is it a 6th gear rpm limit.
Reason I ask is my 04 is geared down, and the speedo is close to 185 in the 1/4. actuall mph is 146. Am I gonna hit the restrictor if it sees 186 ?
zx12richard
The Green Monster..
posted February 19, 2006 07:46 PM
It won't.
Doug
Your problem is like a 100 bucks to fix.... Buy a yellow box....
Then set the speedo correct with GPS... Then no matter what gearing your running you can always set it correct.... Then bike won't reach 186 in 1/4 mile.... I have a 17/51gearing and have it set +/- 1mph with yellow box....
supra5677
posted February 21, 2006 07:30 AM
Dude email sbm@superbikemike.com..
Mail him your ecm he will send it out and get it reprogrammed for you.. Bike will rev 600-700 more in gears 1-6.. Worked for me..
supra
zx12richard
The Green Monster..
posted February 23, 2006 04:36 PM
Got this email back from Superbike Mike... Therefore the extended ecu will give you more rpms but still peter out at 186mph... Thats how I take this..
Date: Tue, 21 Feb 2006 12:57:48 -0500
To: fxhunt@yahoo.com
Subject: Re: RK
If you need to remove the sped restriction, you have to put in a resistor to fool the ECU into thinking the motor is in 5th gear. I don't do that here, but any knowledgeable electronics guy could do it.
The modified ECU will give about 1000 more RPM for $700.
Superbike Mike
fxhunt@yahoo.com wrote:
Can you remove the speed restriction on the 04,05 ZX12's?? I know you can extend the ecu but can the restriction be removed>>> And how much... Thanxxxx
zrexpilot
posted February 23, 2006 07:04 PM        Edited By: zrexpilot on 23 Feb 2006 19:06
It not that easy. each gear has a voltage value when in gear and when not in gear.
5 volts not in gear 0 volts when in gear.
so when your in 5th its recieving 0 volts when you shift to 6th, 5th becomes 5V and 6th becomes 0V.
So what i have to figure out is when I shift to 6th, 5th stays at 0V and 6th stays at 5V.
Resistors aint gonna do that.
this is gonna take some thinking.
you cannot just cut 6th and splice it to 5th, because when in 6th, its puttin out 0 volts but 5th will still be recieving the 5V so the 5V will cancel out the 0V signal from 6th.
Understand?
it would be easier if the V values were the other way around.
0.22397613525391 seconds processing time
