BIKELAND > FORUMS > ZX12R ZONE.com > Thread: K&N pc3r? NEW TOPIC NEW POLL POST REPLY
Cowboy
posted March 23, 2002 09:08 PM
K&N pc3r?
How do you tell the difference between the 3 and the 3r?
Charles
posted March 23, 2002 09:13 PM
The part numbers should be different.
Thanks,
Charles
info@streetntrackimport.com
Cowboy
posted March 23, 2002 09:18 PM
could you tell me the different part#s please?
eric00zx12r
posted March 23, 2002 10:52 PM
the 3r is 83204-311. I think the 3 is -211
Eric
00ZX-12R
Candy Persimmon Red
H
posted March 24, 2002 04:13 AM        Edited By: H on 24 Mar 2002 04:14
PC3R
The DynoJet Site lists the "211" for both the 3 and 3R. for the ZX12. Most of the other models have "211" for the 3 and "311" for the 3R.
Cowboy
posted March 24, 2002 09:26 AM
The power commander i recieved only has the one large connector(split into two)and the main power you connect to the rear tail light connecter.On the gsxr 1000 i did it came with one more connecter for the timing.I the timing for the 12 all built into the large connecter??
Charles
posted March 24, 2002 09:55 AM
418-204211 PC3
418-204311 PC3R
These are the K&N power commanders.
Thanks,
Charles
Cowboy
posted March 24, 2002 01:51 PM
Thanks Charles,next problem is there are no part #s on the power commander itself
Tearinitup
VP Code Monkey
posted March 25, 2002 08:31 AM
The PCIII and the PCIIIr both have similar connectors. Thare have been several discussions on this topic and a k&n power commander is exactly like a dynojet power commander.
fast
posted March 25, 2002 08:54 AM
Hey cowboy !if you want to test if its really
a r put a map with a lot of retard timing so it
wont hurt the engine and see if the motor run the
same ,it should cut some pep less agressive!
9.29@151
Cowboy
posted March 25, 2002 04:47 PM
Thanks guys,i feal a bit better.I don't even have it on the bike yet but i'll hook power up to it and see if it will take timing in the next couple days.
0.26358890533447 seconds processing time
