BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Throttle body air bleed screws? NEW TOPIC NEW POLL POST REPLY
gozx12
posted March 23, 2002 02:06 PM
On the ZX11 carburetors, there were four air bleed screws, sealed under a soft metal plug on each carb, which were used to balance the air bleed rate between the carbs. Is there a similar screw on the throttle bodies, and if so, is it located under the copper-colored plugs with the little holes in them?
Y2KZX12R
CompetitionCNC.com
posted March 24, 2002 07:25 AM
Yep.
0.28840589523315 seconds processing time
