BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Nicasil bore plating... NEW TOPIC NEW POLL POST REPLY
Y2KZX12R
CompetitionCNC.com
posted January 18, 2006 06:38 PM
Has anyone done any milling to the block with this plating? Does it flake off? Chip?
aliveagain
posted January 18, 2006 06:51 PM
I was told it would flake on the perimeter.
blitzkrieg
Road kill = Free lunch.
posted January 18, 2006 06:58 PM
I brought this up in a prior thread (as a joke) as we all know standard honing/boring techniques won't work with Nikosil and somebody suggested that a diamond impregnated honing bore would work in theory.
I've never seen such an animal but if you find one and try it let us know how it works.
GUNNER
posted January 18, 2006 07:27 PM
Yea it would be hard to say how it would hold up on an edge. I would guess that would be the easiest place for it to flake away. I know that in the cylinder way it will take a beating. We had a Jesel lifter break the roller tip and some parts found there way to the bottom of the motor. The crank was tossing parts up into the bores and it never chipped the coating. Beat the piss out of it but never chipped it anywhere. This was a car motor with nicasil liners. Sort of the same I guess
posted January 18, 2006 10:26 PM
I'm told you have to use a surface grinder to mill a nikasil-ed block. Millennium ground .003" off mine to true it up.
01zx12r
posted January 19, 2006 07:47 AM
When I had my cylinder replated due to a head gasket failure, I also asked them to true up the cylinder. .005 is what they had to take off the cylinder. Be sure you ask them how much. You will have to add a shim to make up the difference under the cylinder depending on clearances.
Lovett Racing/Pedigo Performance
8.40 @170
posted January 19, 2006 08:00 AM
Glad to be reading this because I am looking at cleaning up the cylinder top!
Y2KZX12R
CompetitionCNC.com
posted January 19, 2006 09:49 AM
well the reason for the question is actually because I want to mill windows in the block.
So i guess i should ask, if milling windows in the nicasil lined cylinder will it chip?
Y2KZX12R
CompetitionCNC.com
johnnycheese
posted January 19, 2006 10:33 AM
talk to millieum
posted January 19, 2006 10:40 AM
talk to millieum
AGREED!!
GUNNER
posted January 19, 2006 11:17 AM
It would appear that if those windows were milled first it would be a NON issue. Hmmmm.. Food for thought if I ever bore my own 12. Thanks Jim for keeping us all thinking. A little prevention is worth a lot of cure eh??
Y2KZX12R
CompetitionCNC.com
posted January 19, 2006 02:47 PM        Edited By: Y2KZX12R on 19 Jan 2006 16:45
Well I called millieum and they say it might chip and flake a small amount close to the cut.
But seeing as how its going to get radiused and reshaped after the cut and the rings nor piston will ever touch the window area, it doesnt seem it will be an issue.
posted January 19, 2006 07:47 PM
Not tp w.orry. Just dress the edges with a fine stone.
D.
Marcos Peguero
posted January 20, 2006 04:51 AM
I did a honing before using new rings and it runs like heaven
  Ignore this member    Click here to visit Marcos Peguero's homepage.
0.22497892379761 seconds processing time
