BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Is it a PCIIIR NEW TOPIC NEW POLL POST REPLY
hotrodninja
posted March 19, 2002 04:48 AM
Is it a PCIIIR
I know I've seen a post somewhere that discussed the way to tell if you had a PCIII that was actually a PCIIIR. Does anyone know what wires you had to look for?
Be consistent, win money.
kcadby
posted March 20, 2002 12:00 AM
Try loading a map that HAS timing in it...if it is accepted then you DO have an "R"...
Right? Tearinitup???
Tearinitup
VP Code Monkey
posted March 20, 2002 07:34 AM        Edited By: Tearinitup on 20 Mar 2002 12:02
No... PCIII's will take ignition tables too. They just don't know how to use them. The easiest way to tell is to retard the hell out of your timing in the 100% column and get on a dyno or turn on your ass dyno and see if you lose a whole bunch of power.
There are a couple of ways to tell if you definitely have a PCIII. The early PCIII's don't have the brown and brown/white wires in the harness. All PCIIIr's have these wires however so do some later PCIII's.
If you have the brown and brown/white wires in your harness and they are shorted together. ~0 ohms. Then you definitely have a PCIII. If not you may have a PCIIIr or a PCIII.
The only real way to tell is to move the timing and see if it affects it. If you bought a PCIII it is probably a PCIII even if it is mislabeled.
hotrodninja
posted March 20, 2002 10:22 AM
Thanks, That's what I was looking for.
0.41877198219299 seconds processing time
