BIKELAND > FORUMS > ZX12R ZONE.com > Thread: strange noise NEW TOPIC NEW POLL POST REPLY
jus1975
posted November 19, 2005 12:21 PM
strange noise
I just put the bike back together after getting the frame chrome plated. Have a strange sound when I turn the ignition. I also had the FI light come on while it was running. I twould go off when I blip the throttle then come back on. Fired it up this morning and the light didn't come on, so I guess it worked itself out. But the noise is still there. Its not the fuel pump. It sounds like its coming from the top end of the engine. And my fans are not working. I have tried jumping the switch and it didn't work. The bike is an 04 ZX12. Could it be something dealing with the air switching valve or the acuator.
frEEk
posted November 19, 2005 01:33 PM
does it just happen for a second or so after turning the ignition on or is it continuous?
lietoome
posted November 19, 2005 06:27 PM
allergic to chrome would be my guess.
Gunner
posted November 19, 2005 07:16 PM
Yea it's a clear case of chrome rejection!!!!!!!!! I've seen this a 1000 times at least
jus1975
posted November 20, 2005 01:26 PM
does anybody know whats going on?
aliveagain
posted November 20, 2005 07:41 PM
Any codes showing up ?I don't know what you mean by air switching valve.Is your fuel return line pinched?
posted November 20, 2005 07:44 PM
if you did not do any motor work I would say you have an exhaust leak.
if you did some motor work, did you check your valve clearance? speaking from experience here....
jus1975
posted November 21, 2005 06:48 PM
no motor work. it makes the sound when you turn on the ignition. Its not like my 02 it has an air switching valve and acutator that goes to the reed valves. not sure how it works but you just cant take them off and put the muzzy caps on. there is some electrcal connections so I guess its tied into the system somehow.
tuusinii
posted November 22, 2005 11:49 PM
If the caps aren't seating properly it makes a noise. Shouldn't make any FI problems thouhg. When You put the caps on did You remember to plug the remaining holes to throttle bodies and air box?
jus1975
posted November 23, 2005 02:51 PM
I did not put the caps on. I am saying that you can not do that on the 04 as easy as the previous models because you have an electrical circuit invovled.
ninja12
posted November 23, 2005 03:35 PM
check battery ground.
scooter trash
posted November 23, 2005 06:31 PM
Assuming you still have the Kleen Air (should have taken that off if you didn't) OR left the Kleen Air covers on and blocked them off look for a leak there first.
If the Kleen Air ports are open or not sealed properly they make a hell of a racket that sounds like either a really bad exhaust leak or running a motor without shims.
There is a sensor on the back of the cylinder bank (A model, not 100% on the location on the B) that is really easy to knock off and will put up a red FI everytime, but it will be intermittent depending on coolant temp. Easy to miss that one and hard to see when the bike is together.
0.28682684898376 seconds processing time
