BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Using front wheel as turbocharger NEW TOPIC NEW POLL POST REPLY
238mph
posted November 08, 2005 01:11 PM        Edited By: 238mph on 8 Nov 2005 13:12
Ok, I got this crazy idea as a mechanical engineer.... (we often dream about these things)
Here's the idea... specially designed front fairing that has air intake (ram air) in the front
of the fender. Then, the front wheel is designed as a large turbine compressor.... with
an exit hose coming off the backside plumbed into the front air intake.
The faster you go the more boost it makes... Tren, am I nuts or on to something????
Pilot Powers took me to the grave, and brought me back...
  Ignore this member    Click here to visit 238mph's homepage.
trenace
posted November 08, 2005 01:48 PM        Edited By: trenace on 8 Nov 2005 17:18
It seems to me the most efficient draw of power is always off the crank, rather than putting the power through the transmission, the chain, the rear tire, and then suffering further losses from the added aero drag being less than 100% converted to the power required to drive the compressor.
I do however have a very high opinion of the concept of a system that naturally tends to make boost as a funtion of road speed (or rear wheel speed) rather than engine speed, as for a supersports bike little if any boost is useful in say first gear at high rpm as the bike is traction limited, but in higher gears (or rear wheel speeds) it is.
So a supercharger driven off the countershaft could make a lot of sense perhaps. Faster you go the more boost you have, no lag. With the amount of power the tire can take before losing traction being directly proportional to the speed (which it is) doesn't it make sense for the engine's power, its supply of air, to naturally be in proportion to speed?
That really is in the same family as your idea, both being wheel-speed driven. While the countershaft would still suffer the efficiency loss (compared to taking off of the crank) of going through the transmission, it would bypass the chain, tire, and aero conversion losses but otherwise seems a really similar concept.
rac4it
Bergie
posted November 08, 2005 02:10 PM
Turning will be an issue
deathpulse
posted November 08, 2005 03:04 PM
Won't the increased drag on the wheel be more of a problem?
zx12mark
posted November 08, 2005 05:08 PM
is'nt the front tire off the ground most of the time with a turbo anyway.
rc51eviltwin
posted November 08, 2005 05:14 PM
well looks like it may create a problem when you launch and on hard accel. since the front wheel likes to "hubber" just above the gound .also sounds like a air/fuel ratio nitemare.the ram air is already "free"power.but what do i know!!!!!
2000 ZX12r>>sold
2001 RC51>>sold
1988 FLSTC>>sold
2004 ZX10>>sold
'07 GSXR 1000
"05 CBR 1000
'89 NSR 250
'05 metrakit
'03 SV 650
'01 FLTRI
'07 custom hardtail
12r1
posted November 08, 2005 07:27 PM
The stock ram air system starts to really help at around 100mph, right?Would a spinning frt wheel create a faster intake charge than that, below 100?
This kind of thing is very interesting to me. Keep thinking, 238.
When the Monster Snorkel came around, I thought it would be a good idea,ramming more cfm into the same intake tract. Did'nt really pan out though.
jeff
12r1
posted November 08, 2005 07:35 PM        Edited By: 12r1 on 8 Nov 2005 19:47
A while back, I was toying with an idea..
Using the stock intake charge to spin some kind of impeller/propeller at an increased rate to create boost. That's all a turbo does, off the exhaust instead of intake.might fudge performance slightly at lower speeds, but wail up top?? I was thinking of perhaps a drum type blower fan, with the intake air powering it. Just thinkin out loud. Never know what a few speed freeks can come up with. hehehe.
jeff
your car is slow
Fuck Nitrous...Got Boost?
posted November 08, 2005 08:32 PM
really doubt it would spin fast enough to be terribly effective.
Do not taunt happy fun ball!
posted November 08, 2005 10:10 PM
I think 238mph has been sipping lattes' with Dr Turbo...... drturbo.com
trenace
posted November 08, 2005 10:35 PM        Edited By: trenace on 8 Nov 2005 22:36
Hmmm, what with "Mr Turbo" and "Dr Turbo" already taken as company names, if I ever do a turbo company I suppose that leaves me only with "Reverend Turbo"
posted November 08, 2005 10:52 PM        Edited By: TurboBlew on 8 Nov 2005 22:52
THere's always Turbo Doctor, PHD......lol
tuusinii
posted November 09, 2005 03:07 AM
What I like to have as a turbo (and I generally don't like them anywhere: car, bike...) is a electric supercharger. So You could have whatever boost You wanted at what ever RPM or speed You needed and without lag! Problem would be that supercharger take a lot of energy to pump the air so with generator and motor the efficiency would drop...
238mph
posted November 09, 2005 07:21 AM
Did someone say TURBO LATTES????....
On the flip side, I'd like to see someone pull suction on the exhaust....
Then you could have a four stroke machine that was actually a 2 stoke, and DOUBLED
the HP !!! On the bottom 1/3 of the downstroke you have suction that pulls out spent gasses AND draws in fresh air/fuel... then compresses on the upstroke, so it fires at
every TDC (normal timing of course) 2 stroke baby... in a 4 stroke engine...
0.29319000244141 seconds processing time
