BIKELAND > FORUMS > ZX12R ZONE.com > Thread: valve guides NEW TOPIC NEW POLL POST REPLY
aliveagain
posted October 05, 2005 11:03 AM
valve guides
I just got a call from the machine shop that is doing my head.He told me all the exhaust guides are worn and those were the ones where the emissions bullshit attaches to.The holes were all clogged up also.The dealer wanted $25 apiece for the guides and 6 for the seals.APE had the guides for $112.20 and seals for$37.95 for a set of 16 each.20,000 miles on the bike.I figured to give a heads up to anyone taking their head off.
How do you remove the valve plates on the valve cover?
posted October 05, 2005 11:24 AM
Valve Plate? On the Valve Cover? What plate on the cover
aliveagain
posted October 05, 2005 01:10 PM
the reed assembly.mine is caught in there pretty good,channel locks wouldn't even pull them out.
ZXLNT
posted October 06, 2005 09:19 PM
Cut them in halve with a slitter wheel.
aliveagain
posted October 07, 2005 07:19 AM
I thought you were fking with me until I googled slitter wheel. I'ld rather not cut them if I could help it.
posted October 07, 2005 03:36 PM
I have never had a problem with the Kleen Air reed valves. Poke them through the Air Holes under the Valve Cover
aliveagain
posted October 11, 2005 02:22 PM
Tried Vincent,holes are at an angle .I ended up spraying choke&carb cleaner and that loosened the gum right up.Then I slid an o-ring pick down the outside and was able to free up the reed valves.I'm still waiting on A.P.E. for the guides.
aliveagain
posted October 12, 2005 02:15 PM
Just got the guides and seals.Are the seals the same as the hayabusas?APE sent me seals for a Suzuki 1300.
ZXLNT
posted October 12, 2005 10:38 PM        Edited By: ZXLNT on 12 Oct 2005 23:49
Good question I can't find anything on the APE site..
Email Jay he will help ya.
Jay@aperaceparts.com I believe..
Looking further it appears they have the same part number from APE, so they should be the correct ones..
0.27022695541382 seconds processing time
