BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Installing Bar Grips?? NEW TOPIC NEW POLL POST REPLY
beansbaxter
posted September 30, 2005 06:33 PM
Is there a trick to putting bar grips on? The service manual says to use some sort of cement, but how do aftermarket grips slide on with a cement adhesive?
What is the trick to making the grips slide on with ease and staying stuck in their locations once they are on??
waltdog
EDM guy
posted September 30, 2005 07:02 PM
The best stuff I have found is the Pro Honda grip cement. Allsport stocks it,unless you want to go to westside,they should have it too.anyways the stock grips can be removed by slowly peeling them back and working some contact cleaner under them (electrical contact cleaner) or cut them off with a razor. In most cases you will want to remove the throttle tube from the throttle assy while the grip is still on,that way you can put a mark on the tube indicating the most amount the new grip should be slid onto the tube. Then clean all the old glue off of the tube and also the left hand clip on. green scotchbrite usually does the trick there. Now take your new grips and wash them in hot soapy water then let them dry completly. now for the glue! smear some on the whole clipon a little inside the grip helps too then slide it on working quickly to get it positioned where you want it,you can rotate it a bit to make sure the glue is spread about. The throttle side takes a little more care as you dont want any glue inside the tube. apply glue same as left side just have to get rid of any excess in the tube right after you slide the grip on. alot of times aftermartket grips are a tad longer so they need to be trimmed a bit on the throttle side because the bar end tends to hinder movement of the grip.
There's a dead hobo on the patio
And an old barbed wire on the funeral fire
beansbaxter
posted September 30, 2005 07:23 PM
waltdog are u from spokane???
lietoome
posted September 30, 2005 08:29 PM
took them off with a razor( if for some reason you wanna keep them, you can also use an air compressor and they will come off with little work.). Sprayed some enamel paint inside the grip and slid them on. Worked like a champ.
zx12adam
Member
posted September 30, 2005 08:44 PM
Hair spray.
I'm not kidding.
Hells Dark Lord
living life, and loving it.
posted October 01, 2005 05:05 AM
I use hairspray as well......and if you tkae a hair dryer to the grips after you have them in place the hair spray will set up in a matter of minutes.....
zx12adam
Member
posted October 01, 2005 06:28 AM
Good idea, I'll do that next time.
posted October 01, 2005 07:24 AM
Muscle them on and safety wire them. NOTHING works better. You'll notice most grips have little channels to sink the safety wire in.
Tried for years to keep my dirtbike grips from "spinning".... even used every adhesive known to man...
waltdog
EDM guy
posted October 01, 2005 10:22 AM
Yes,but now live in Post Falls, I really like Allsport the parts guys are great and the staff is top notch. I bought my CBR600F4i from them. Even after switching to Kawasaki I still go to Allsport for oil,ect..
posted October 01, 2005 08:14 PM
SOme people do not have air and that does not work easily for newer grips with opened ends.
I take a small flat blade screwdriver and a can if Cheap Brake Cleaner and some Paper towels.
Put the straw on the brake cleaner and with the thin long blade screwdriver slide it under the gripabout an inch and squirt a little cleaner. With that you can then push the blade a lit farther and squirt again until the blade is all of the way through. squirt again while working the blade around and once a 360 had been made the grip slides off. Immediately spray the new grip and slide it right back on and the "Original" factory glue will dry and hold the new grip.
SOmetimes when selling the bike a person will want the original Parts. I then give them the old grips, exhaust, seat and everything (Cleans out my basement too)
chriscollins
posted October 02, 2005 07:19 AM
Aquanet hairspray it works great! let dry for a day
vozizm
Got Nothing Witty To Say
posted October 02, 2005 12:25 PM
When i installed my Heli bars.. i used compressor to remove, and simply put them back on with any adhesive... right one spun for about half a day , after that no problems..
VOZ
posted October 02, 2005 11:07 PM
Hair So New with "extra hold"
(as chriscollins says, let it sit 24hrs)
0.25142502784729 seconds processing time
