BIKELAND > FORUMS > ZX12R ZONE.com > Thread: ZX12R Swingarm Extenders NEW TOPIC NEW POLL POST REPLY
wekoli
posted September 22, 2005 01:25 PM
You know, The ones on eBay for $175.00. Looks like a bracket that bolts to the axle and extend the rear wheel out. Anyone have them? Good or bad? Would it be safe to run a chain with a master link in 2 places so I can change out the extenders to put back to stock? Your thoughts on them? Aloha, Victor
aliveagain
posted September 22, 2005 02:05 PM
I have a set I paid $150 for at 0-6" extension.Fit was super tight and the only complaint was the brake bracket was off alittle but still works.I thought about taking mine on and off but just ended up leaving them on as I would have to adjust the ride height also.Too much of a hassle so I just ride as is.I also use 2 master links with no problems.
yzfone
posted September 23, 2005 09:31 AM
What ALIVEAGAIN said. No problems.
JUNGLE JOE
posted September 24, 2005 09:17 PM
Yea whats up I dont have the set youwant but I have the parts from exotic cycle that bolt into the stock position and allow from 2 to 7" of adjustment so if you changed rear sprocket size you would not have to add or sub. links also I miss doing throttle wheelies! later.
wekoli
posted September 25, 2005 09:15 AM
Aloha Jungle Joe, You iinterested in selling what you have? I sent ya a PM.. Aloha, Victor
JUNGLE JOE
posted September 27, 2005 07:06 PM
Yea whats up /aloha hey I am using them man so good luck with that,later
0.2629451751709 seconds processing time
