BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Excellent Black Paint for wheels, Oil Pans and other things! NEW TOPIC NEW POLL POST REPLY
posted September 21, 2005 04:12 PM
I usually use Epoxy gloss Black or Mat Black for anything that oil, Brake Cleaner or Carb cleaner will touch. Tonight I tried VTH Brake Caliper and Brake Drum paint. Said not effected by "Chemicals" and good for about 900 Degrees..
It is sort of a semi Gloss and to paint my front wheel (Remember I, well Randall bent the last on at Maxton) I used a short jack handle and a bungee with the ends on both sides and hung it up. A few wraps of Duct tape on each side to keep it from sliding and I was painting.
As soon a I got finished I took a folded paper towel soaked in brake cleaner to clean the center of the rim and only the Actual Over spray came off. It did not even dull the paint where it was on fairly well. This is serious stuff and it had not even dried hard yet. So I am glad I had masked off the area where the Brake Rotors go after cleaning the area because I would have had to use a razor Blade or something to get the paint off. It is just a little shinier than stock. looks like I used WD 40 to clean the wheel.
BTW, it also states it is not easy to chip or scratch this stuff either! I will know more on that later while I am mounting the tire
gunner
posted September 21, 2005 06:16 PM
Sounds good Vince..........I used Gun Coat finish on mine and it's tough as hell as well. It stays on pistol slides after 1000's of rounds fired thru them. You do have to bake this stuff though. But NO chemical will remove it. It has to be blasted off.
Like you I've used Epoxy for this type of stuff for years. I used it to paint my case covers on the 12 and it looks factory perfect and oil won't hurt it at all. I'll get some of that stuff you used and try it on something. Actually I need to paint the calipers on the second 12 with something so I'll give this stuff a go. I powdered the other 12's calipers and it's a PITA!
Thanks Vince
kawachan
posted September 21, 2005 06:26 PM
Where you get it at Vincent?? I am going out searching. I need to paint some stuff on the 10.
RED NINJAS RULE!!
posted September 21, 2005 07:35 PM
AutoZone Not the Cheapest Paint, but not out of sight either at $7.95, Make sure you mask off "ANYTHING" you so not want to paint because it will not come off.
Yes, I used KalGard Gun Kote back in the late 70 and early 80's for my cylinders and cases not to mention the pipes. Stinks Like Hell 0 while baking. Sort of an dark Gray black color
gunner
posted September 21, 2005 08:08 PM
If you order it direct you can get extra pigment put into it and it can be made blacker that way. Only down side to it is if you over bake it for too long a time or too high a temp it will start to change colors Guess how I know this? NOt to fear though all you gots to do is reshoot and presto!
posted September 22, 2005 02:20 AM
Vince,
EXCELLENT tip;
I have been looking for a hard surface, fast drying satin black paint for a long time.
Thanks!
PS: I think you meant "VHT" (rather than VTH)
posted September 22, 2005 05:12 AM        Edited By: VincentHill on 22 Sep 2005 07:35
You would think I could get the VH in the right order (Very High Temp) Epoxy needs 48 hours and this says 2 hours touch and 24 hard dry. I usually do not get this excited over paint, but the crappy painting job and all of the work I had to do to get it off of the red wheel I bought made me aware of just how bad paint can be!
beansbaxter
posted September 22, 2005 05:52 AM
Good info. Thanks.
posted September 22, 2005 08:11 AM
... I usually do not get this excited over paint...
But on the other hand, this VHT is BLACK paint, eh????
Just messing with you, Vincent
posted September 22, 2005 10:50 AM
And here I thought is was "White" paint that was supposed to do that
ninerrider01
posted September 23, 2005 09:47 AM
Hey, interesting thread since I need to strip and paint a wheel.
Do you use any primer before using this paint?
Did you strip it down to shiny aluminum then paint, or did you strip to aluminum then scuff it a little?
Obviously, I'm clueless on prep.
posted September 23, 2005 01:23 PM
All paints are different so this is not a case of being clueless!
I used aircraft pant stripper because I had the Junky red wheel than someone had sprayed a horrible resistant to nothing Dull Black paint. I tried to use thinner and toher things but the process was too slow and the stripper took all of the paint off the edges and left the red in the middle and on the spokes. I cleaned up everything with brake cleaner and sprayed away. No sanding, No Primer, no nothing ! That is how good paint is supposed to work!
So I had Shiny Aluminum, Rough surface cast red Paint and smooth read paint. Stuck to all the same! could not get it off as soon as it was sprayed!
zx12adam
Member
posted September 23, 2005 03:16 PM
Work on exhaust? Maybe further from the heads?
CBR1000RR
Best Literbike: Performance Bikes, Superbike, BIKE, MCN, Road Racing World, and Motorcycle USA
posted September 23, 2005 04:11 PM
NO! The #1 thing I have found for exhaust (Even Chrome unsanded) is the Header Wrap Paint. SIlver or black. Very thin and about 4 to 6 coats and you can only scrape it off. Even after red hot no problem!
zx12adam
Member
posted September 24, 2005 06:08 AM
Header Wrap paint? As in wrap the headers and this is for painting it? Or is it just a name for a paint that goes straight on the pipes. If I end up getting a bike that happens to have an undertail exhaust I'm blacking out the pipes going up to the muffler.
posted September 24, 2005 12:06 PM
HT Silicone Coating "DEI" (Design ENgineering Inc.) Makes it Protection ups to 1500 degrees F (Use on Header Wrap or Exhaust)
Comes in a Blue wrapped can with Yellow writing! Made in Avon Ohio 440-934-0800
0.21825313568115 seconds processing time
