BIKELAND > FORUMS > ZX12R ZONE.com > Thread: no spark or fuel NEW TOPIC NEW POLL POST REPLY
aliveagain
posted September 20, 2005 07:52 PM
no spark or fuel
My bike had been running pretty rough lately and was fouling out spark plugs.Now it won't even start.I had my brother bring over his test equip.and checked the ecu.We have power and good ground readings.Next we tried plugging a test lamp into the injector connector and the coil connector and get no signal on either .Any ideas on where to procede from here?Tomorrow,after the battery is fully charged,I'll pull a coil and put a spare plug in to check that way.I've checked every sensor and they all are good,coils are within limits and no fault codes.I have a PCIII,not the R,but I'll try unplugging it and see if it'll run without temporary.I also need a wiring diagram for a Muzzy Digi-kill if anyone has it.
email is PSteinis@sbcglobal.net thanx in advance
osti33
posted September 20, 2005 08:25 PM
Did you just put the digi-kill on? Try taking it off and see if the bike starts. It might be wired wrong.
scooter trash
posted September 20, 2005 08:26 PM
You cannot "test" the ECU.
Per Kawasaki service procs the ONLY way to test the ECU is to replace it with a known good unit.
aliveagain
posted September 21, 2005 02:57 AM
My digi-kill has been on for awhile but the last time the bike was worked on,I was told it was wired wrong and he fixed it.We're not sure if I can just unplug the connector or if we can or have to jump it out to see if this is related to my problem.
The ecu we checked all the grounds for conductivity and the white wire for 12 volts.Another wire was checked for volts with and without the ignition on as per manual.
Ra12r
posted September 21, 2005 06:57 AM
Make it simple,
1)UNPLUG the PC3!!!
try to start, and leave disconnected till problem is found
2) Disconnect digikill
try again, continue till you find it
posted September 21, 2005 11:01 AM        Edited By: VincentHill on 21 Sep 2005 12:04
No but there is a test for everything the ECU Controls and once you have done that, you have indeed tested the "ECU".
My Question is the biks sending out any Codes?? Remember when I did the tests for the Fuel Pump I ended up finding that the ECU was BAD>
better than trying a good ECU on your bike, have someone try your ECU on their bike (Has to be the same year for 00, 01 & 02. I do not know about 03 & Up.
scooter trash
posted September 21, 2005 03:50 PM        Edited By: scooter trash on 21 Sep 2005 16:56
Its all perspective Vince.
I'm just stating what a Kawasaki tech at KHI headquarters told me point blank. There is NO way to test the ECU. Its non-serviceable.
There is process of elimination, but that is not foolproof and beyond the skill level of probably 95% of the riding public.
Case in point:
Remember the guy on .org that was convinced his ECU was bad because all the sensor i/o was spot on, and I told him to swap the ECU first, and when he did the bike still ran like crap.
The outcome was after he finally saw concrete proof it wasn't the ECU and all the sensors were good he said "Oh yeah, I did pull some wires to blah, blah, blah..." and we determined after many closeup photos that he (didn't tag them before removing them) and had the TPS wire and MAP sensor (or altitude or whatever, don't remember OTTOMH) crossed and that was it. Stupid mistake but shit happens to inexperienced people playing with wrenches.
So the point still stands. There is NO way to test the ECU such as an OBDII interface like on cars (sadly).
posted September 21, 2005 04:02 PM
Possible that you, Me Entropy (Other than DM and the Muzz Man) would go through the "process". (Then I sent the ECU to Dan to see if what I thought was wrong was! It was and now I have a new ECU)
aliveagain
posted September 21, 2005 06:49 PM
I will say that I had asked RA12r about a battery ground that I had forgotten to attach when installing my motor.I bolted it on the clutch cover and wondered if a bad ground was my problem.I have since reattached it to the casing.I unplugged both the digi-kill and the PCIII and still no spark.I just checked for codes again and I get a steady blinking and doesn't stop.They're all long and no short,.I don't have the manual at home,what is this a code for?
scooter trash
posted September 21, 2005 08:34 PM
I'm the new kid in town here on www.FISH, aliveagain, and I'm certainly not here to rock the boat.
But... I've been following some of your posts and I am curious what your background pertaining to motorcycles is. Just looking for some background.
aliveagain
posted September 22, 2005 02:49 AM
I'm just an old crackhead,married with children,that tries to do my own work.I would be much better off bringing it to a shop to have the work done but that would take too long for an appointment and too expensive.I might have some goodies on the bike,but thats from selling my Harley.My skills are only that of a general mechanical background but I find working on my own bike invigorating and confidence inspiring.Working a 12 step program tells me to keep asking if I need help and this site has been wonderful.I've also solved some problems on the bike through prayers,it's just this one hasn't been answered yet.
I do maintenance on air compressors for a living so the job isn't for the most part challenging.
aliveagain
posted September 22, 2005 12:31 PM
Dammed if I know but I put a spare plug in a coil I pulled and the bike started right up.I hope its not a bad pin someplace because that sounds like a pain in the ass.All I did was put a charge back on the battery and reconnected the PCIII and dig-kill.
scooter I went from a 77 750 honda to a suz 400,68 sportster, 1100et,yama venture,88 FLHTC when I was in an outlaw club and then the ZX12R
aliveagain
posted September 22, 2005 05:51 PM
I just took the bike for a test ride and it didn't run on all cylinders for about 100 yards and then cleared up.Over 20 mph the bike runs good with very little on/off throttle.Under 20,it sounds like a nitro burner,it loads up.I wish I can download the map thats in there now so I can take some fuel away.It'll show me rpms,tp and duty cycle but no numbers.I'll try something tomorrow but the prayers are starting to be answered.I might even be able to do a test and tune Saturday.I may even spray and try out the bottle heater.
Ra12r
posted September 22, 2005 06:22 PM
Sounds like you have a corrupt map. I don't know if you are using the numbers I gave you, but now that it is running, try just loading a new map. Even if it is the same one.
aliveagain
posted September 22, 2005 08:08 PM
I wish I could,but I don't have a copy.I guess I could try loading one of the CD maps just to compare and get into the PCIII.Someone told me I actually have a PCII because mine has a ground wire that must be hooked up and the CD tutorial says this.Whats the difference?
I just went back and looked at the numbers you sent me and they are alot more than what I remember back a week or two when I was at ECP.I think my #s were around 15.I'm still concerned about the syncro because its been adjusted so much it caused the cam on the fast idle to not even hit the throttle.So I try to learn a little bit every day.
aughtsix
posted September 22, 2005 08:45 PM
I think you should clean and gap your points.
Just kidding...
posted September 23, 2005 12:43 AM
....Someone told me I actually have a PCII .....
Musta been a Busa guy (they ran PCII's).
To my knowledge, 12's never used a PCII.
get RA to resend you his map or post yr motor/exh config and someone here will send you a map which should be close. plenty o' maps available!
aliveagain
posted September 23, 2005 02:35 AM
I have a superbike Mike 1320 with a 4.6 stroke crank,running a Ti-Force exhaust.
aliveagain
posted September 23, 2005 06:14 PM
Balls,I'm taking the bike off the road.It's just to dangerous the way that throttle is.I'm going to run it at a test and tune tomorrow but no more on the road until I can afford to have the injectors resyncronized.I'm pretty sure that is why the high idle lever doesn't even touch the throttle.I want to have it remapped by someone other than ECP.Freddie may be a good wrench but without an o2 sensor he has no way of knowing where the f/a is,only if it makes power.Seeing as I only have this problem at the very beginning of the throttle opening,I'ld like to try and see if there is any dead spots on the tp sensor.I have also been noticing an electrical smell when I come to a stop,maybe I'ld better check the alternator wire and connector.Guess I'should put this in the winter projects thread.
Outlaw1
posted September 23, 2005 10:25 PM
Unplug power comander,
Check your pigtail connector in tail section for oil. You could be burning up your harness, That melting wire smell is bad.
Lead, Follow, Or get the hell outta the way.
johnnycheese
posted September 24, 2005 04:59 AM
the first ones were labled PC2 but it really was a 3,
just use then buttons to lean out the low end till you get her mapped. and yes I have been bitten by a new plug not fireing, anyother bike I would have found it but on a 12 I would rather check anything then pull a plug
aliveagain
posted September 24, 2005 04:58 PM
Well I'm retiring the bike for the year.Took it to the track and left a cloud when I took off but cleared up as I went.Second run I actually tried the spray but I short shifted and hit the rev limiter once.Third run I ended up running without the nitrous for spray and shifting and did a personal best of 9.722/144 footshifting.Hey Bergie maybe you got something.Every time I picked up my slip,I'ld leave a white cloud and a little trail when slowing down.Suspect water leak but I'm tapped and I'm going to park the bike until I save some money.
On a side note,a rider wiped out on the track at the big end because he hit his front brakes so he wouldn't foul out.He walked off the track but my wife and kids just happened to come and didn't need to see this.
Ra12r
posted September 25, 2005 06:47 AM
Alive, your idle problem is because your map is LEAN during idle, plus your numbers need to be staggard as I explained in my email. I haven't sent you any maps yet, but I can if you desire.
aliveagain
posted September 25, 2005 02:23 PM
Yes if you could send some maps,that would be great.I still don't see how I can be too lean,if my plugs are pitch black by the time it takes to warm up the motor at idle.This is the season for me to start splitting wood for the winter so my time will be on that for awhile.I know its going to bother me so we'll see how long befor I pull the motor and find why it was blowing smoke.On a side note,I would vote no for running one bottle for the shifter and the spray.Maybe its the way I plumbed it but every time I changed a bottle,it would loosen a fitting and I'ld only get one run.
posted September 25, 2005 03:18 PM
AA, sorry to hear about yr problem; could be as simple as a head gasket. Yank that sumbitch out and pull the head. Wood splitting can wait, its not even smowing yet!
0.23852896690369 seconds processing time
