BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Edit - Now with pics: GOOD GOOD NEWS -- 14's dimensions almost identical to 12's NEW TOPIC NEW POLL POST REPLY
trenace
posted September 15, 2005 09:26 PM        Edited By: trenace on 16 Sep 2005 01:41
Good fucking news!
There were two main problems with the overlays I did before. First, the pics weren't taken at the same camera angle. Second, the 14 (or 1400) was not quite straight up and down, but apparently was on its kickstand. Still another problem was that the front rim could not be made out absolutely plainly but actually I think it was readable enough, that probably was not a substantial cause of error.
Had to work with what was available, but unfortunately the results were WRONG. Wish I hadn't posted them. Seemed sound, but wasn't... wasn't until a day or two later that the unreliability became apparent.
We now have Kawasaki's studio pics of the 14 however, taken seemingly at the same or virtually the same camera angle as Kawasaki's studio pics of the 12. Both bikes are vertical, and the rims can be seen very plainly.
Scaling the 12 pic so that the outer diameter of the front rims matches between both bikes -- and both should be identical -- the overlays now come out very different than before.
The wheelbase of the 14 appears only a trace longer.
The bars are only a trace higher.
The bikes are almost overlays with each other. This is not the oversized bike that the bodywork also gives the illusion of it being, or at least when there is no sense of scale, as there was not in those pics.
I wish I could post the overlays! They would show very well and I think this time pretty accurately how the bikes compare. However for some damn reason xs.to is refusing to allow me to upload any pics. If I can e-mail them to anyone that can host them, that could be another solution.
It's good news... it's very encouraging when you see the bikes to scale, compared right on top of each other, it proves this new bike is NOT an overgrown, unwieldy deal.
trenace
posted September 15, 2005 09:46 PM
If you don't mind clicking and seeing the ZRXOA board, I was able to post it there as they can host attachments:
http://www.zrxoa.org/forums/showthread.php?s=&postid=1062297&t=9945#post1062297
trenace
posted September 16, 2005 12:40 AM
OK, got a new hosting service.
First pic is equal "levels" of each bike in the picture. Second pic shows the 12R more plainly than the 14. The last pic is the other way around, "heavier" on the 14. The 14 is the red bike, has the slightly longer wheelbase, and the slightly higher bars:
vozizm
Got Nothing Witty To Say
posted September 16, 2005 04:54 AM
wheelbase?
VOZ
crashtech
posted September 16, 2005 06:26 AM
Well that makes me curious? I will park mine next to one and ride it when they get here.
posted September 16, 2005 06:40 AM
I have a feeling that we wont be disapointed when the ZX14 is tested...
blubyu
posted September 18, 2005 06:30 PM
So is it looking better for swapping the motors? Probably would have to swap a host of everything else too. Injectors, ECM, etc..
Run whatcha brung
Tow whatcha blow
trenace
posted September 18, 2005 06:41 PM        Edited By: trenace on 18 Sep 2005 19:48
Nope. Unfortunately (but perhaps out of necessity) they are quite different.
Specifically, the 14's upper rear engine mount appears 0.6" further forward and 0.5" higher than the 12's, whereas its lower rear engine mount appears 0.3" further back and 0.9" lower than the 12's. These values are relative to overlaying the cylinder heads to identical positions, as judged from the exhausts. There is 1.4" further separation between them in the case of the newer bike.
The error in this type of photographic measurement is percent error, not absolute error, other than pixel resolution. I think error is about plus or minus 1% with these pics. So with the wheelbase, that could be a half inch either way.
But unfortunately, with the motor mounts, whether it's 1.4" of difference or 1% less than that is irrelevant. Even if I were way wrong, say about 15% wrong and it were 1.2" further separation between the lower motor mounts, that would still not be going to "drop in" or anything at all like it.
blubyu
posted September 18, 2005 06:56 PM
OK...how about keeping the 12 cases and switching the internals? I'm know I'm reaching!!
Run whatcha brung
Tow whatcha blow
trenace
posted September 18, 2005 07:06 PM
The basic problem is that to run the longer stroke and meet production standards for durability, IMO longer rods will be used. I'm pretty confident you'll find this bike has substantially longer rods than the 12 does. I wouldn't be surprised if they're longer by 10 mm.
Combine a longer stroke with longer rods, and now there's a greater distance between the crank's centerline and the cylinder head. Quite a bit further.
The only internals you'd be switching would be crank and block. Let's suppose that they fit (they might well not.)
Even if they do, you can't have the cylinder head 13 or whatever mm higher on the ZX-12R than it presently is. Or maybe you could but not without some significant work, probably including reshaping/repositioning the frame openings for the velocity stacks, and including probably a custom exhaust that won't hit the oil pan despite "starting out" a half inch or more higher.
Alternately, I have thought about "tipping" the 12's motor where the top motor mount would stay the same, but (and I didn't check the cases to see if this is possible) the motor was rotated down and back so the mount would go through a more-forward part of the cases. Definitely some substantial custom work there. It might be easier and better to weld up the frame and redrill new mounts than to do that. That also might be the solution for installing a ZX-14 motor.
One would have to extend the cam chain too.
The only "help" from the ZX-14 in making this monster (hugely stroked, more than anyone is now doing) 12R motor would be the longer crank and longer rods... but that's really no new solution, as both are already available (at least on a custom basis so far as the rods go. No big deal ordering them.)
ozzy
need guberment cheese
posted September 19, 2005 06:55 PM
Interesting to see the center of the seats is the same height. Kawi's press release says it has a loew seat height.
Well no one ever accused the 12R of having a low seat , so how can this now be considered low?
They comparing it to a Buell XB12X or?
The 'busa seat is over an inch lower than the 12R, which is/was thier target with the 14. Why is the seat so high? Because they stuck with a monocoque frame instead of going back to a perimeter frame.
ozzy
posted September 19, 2005 06:56 PM
the bars appear to be over an inch higher at the end weight.
trenace
posted September 19, 2005 09:06 PM
I get an inch-and-a-quarter from pixel count. But , a lot of 12 owners used Helis that are that high, and most that tried it like them, so Kawasaki may have listened to that. I used to myself, though on the 2005 I decided not to put the Helis on, that I preferred the regular.
For that matter, not sure but I thought the B model had lower bars than the A, and so perhaps this is pretty close to the A model. At any rate, it's like the B model with 1st gen Helis, and lower than with 2nd gen Helis, and most definitely not ape-hangers.
Outlaw1
posted September 20, 2005 07:29 PM
Damn when you put the overlay like that the bike dont look so big and gawdy. I will have interest in this new bike from what I see on this overlay,
Thanks Trenace
Lead, Follow, Or get the hell outta the way.
trenace
posted September 20, 2005 07:36 PM
Sure thing Outlaw, glad it helped.
I personally also found the pics with a rider on the bike, and with people standing next to the bike to help judge. The bike really is not physically significantly bigger than the 12; actually the windscreen is a little lower, and the width is either the same or a small enough difference to not be obvious to the eye, from the overhead pic.
lietoome
posted September 21, 2005 07:22 AM
tren, you got skills. Question. Any chance you can chop-chop on the front and rear to give us an idea whit it looks like? I'm thinking 2" in the rear and 1.5 inches up front.
I tried, but it became a photo-butcher.
trenace
posted September 21, 2005 09:49 AM
I can try it this evening.
It's unlikely to come out looking seamless, as that is much harder than the kind of 'chops that I've been doing on it, and really extends past my skills, but would give a rough idea anyway.
Zammy
posted September 21, 2005 02:32 PM
Has ANYONE here seen this bike in the flesh ??? Alot of this group seems to be freekin' out about the looks but I'll bet it's a MONSTER bike up close.
lietoome
posted September 21, 2005 08:01 PM
My curiousity is killing me on what it would look like in all black & slammed.( minus the foreman grills on the side and have a single carbon exhaust? and a bit of powdercoating!)
Straight stealth mode!
trenace
posted September 21, 2005 09:37 PM        Edited By: trenace on 21 Sep 2005 22:40
L2M, here's the chop, pretty crude but about the best I can do personally, with a drop of about 1.5" at each end. Actually I meant to use the stock pic as the starting point but partway through I realized I was working with an already chopped pic, but I didn't want to go back again, still will give the idea -- now of course it would damage the handling, but combine your drop idea with a longer wheelbase and the 14 could look pretty serious:
deathpulse
posted September 22, 2005 08:39 AM
WOW Terance - excellent post, you have some skills my man! What do you do for aliving - study spy pix? .
trenace
posted September 22, 2005 09:34 AM        Edited By: trenace on 22 Sep 2005 10:37
Nope, actually I can barely draw stick figures! Compared to a real Photoshop artist my efforts are pretty lame, but thank you!
Or as for matching up the 12 vs the 14, if the assumption that the outer rim diameter of both bikes is the same (and that seems reasonable enough) then it's not hard to scale the pic of one bike so as to give that same exact size for its front wheel... then everything matches up if that assumption is correct. Or so far as measuring distances go, if one distance is known such as the wheelbase, photo editing programs can measure pixels between given points for you, so you can know how many pixels there are per inch, enabling figuring out other distances if they're in the same plane.
superninja12r
posted September 22, 2005 11:39 AM
Awesome job Tren. I acutally like that model a lot better. Can anyone from Kawasaki please hire this guy because your version sux monkey balls.
deathpulse
posted September 22, 2005 05:36 PM
Yeah seriously Tren - you do some good photochop work bro! . And some interesting analysis! I think the new '14 will look great with a single pipe and some mods.... all black...hmm...
lietoome
posted September 23, 2005 04:47 AM
Beautiful Trenance. I'm guessing lowered with a hugger and a bit taller on the windscreen would do this baby some real justice. Powdercoat the bare aluminum, PC3, black midpipe & single CF can.
With the mods I'd do first...were looking at $erious cash considering this thing will be hard to pick up under retail like the 12's. Not to mention having the whole thing painted Kawi Green.
Would you lose any power going to a single exhaust???? wonder if they are using the 12s restricted ass air filters? Can a 200 tire go on this thing???
BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Edit - Now with pics: GOOD GOOD NEWS -- 14\'s dimensions almost identical to 12\'s NEW TOPIC NEW POLL POST REPLY
0.2517249584198 seconds processing time
