BIKELAND > FORUMS > ZX12R ZONE.com > Thread: FI light stays on! NEW TOPIC NEW POLL POST REPLY
Ra12r
posted September 09, 2005 06:00 PM
FI light stays on!
Does anyone know what a solid FI light is indicating?
1)I checked all the connectors (6) and they are fine. 2)Disconnected the battery, no change.
canadamaxxer
posted September 09, 2005 07:43 PM
You have a hard code stored in the system. The fault is constant and reoccurs when the key is turned on. Disconnecting the battery clears the code that was stored, but as soon as the key is cycled the fault reoccurs. Retrieve the stored codes and post them up here.....we'll see what we can do to help....
posted September 10, 2005 12:24 PM
Do you know how to see the codes?
Ra12r
posted September 11, 2005 10:31 AM
The code is "12"
posted September 11, 2005 11:29 AM
Inlet Air Pressure Sensor, On the left side close to the Throttle Bodies. Maybe the Hose is off or it is disconnected. There are a lot of tests but iI suggest you borrow one or take yours to someone and see if the light goes out!
Ra12r
posted September 11, 2005 01:23 PM
Isn't the air Pressure sensor under the gas tank on the opening to the air box?
posted September 11, 2005 04:17 PM
that's the airbox temp sensor.
The MAP sensor is is on the L side near the TPS, single nut holding it under the frame/airbox, fed by a tube coming off the TB's.
(easy to forget hooking up when installing the motor, yep)
Ra12r
posted September 11, 2005 06:26 PM        Edited By: Ra12r on 11 Sep 2005 19:28
Are all those the same? Cause I broke my original this last install and replaced it with one I had lying around. I checked the numbers and they were all the same, but are they really?
It is the grey plug correct?
posted September 11, 2005 10:47 PM
W,
yep gray plug on the MAP sensor (at least I hope so); black on the TPS.
no idea if all MAP sensors are all the same
Ra12r
posted September 12, 2005 06:07 AM
Thanks Vincent for the reply this weekend. Entropy, can I get the move?
posted September 12, 2005 12:18 PM
ra12r,
it is running again, but i sure as shite ain't giving you the move; i'm supposedly smarter than I look (that's what my wife says to me)
posted September 12, 2005 01:46 PM
ra12r,
You too? My wife even agrees with my signature "Still one fast Old Man"
RA12r
posted September 12, 2005 07:33 PM
I had originally broke my sensor on install and replaced it another. So tonight, I grabbed a second sensor and tried that and Instant light off. So concluding that I had installed a bad sensor to replace my broken sensor was my problem.....WHEW!!!
0.41237688064575 seconds processing time
