zxlnt
posted August 25, 2005 05:08 PM
00 ECU with 01 Engine
Friend has a ZX6R with a 01 ZX12R motor stuffed in it. He had it all running with the 01 wiring harness and such. Now he's switched over to the 00 wiring harness and it wont start now. I know the intake cam rotor is in different position on the 01 engine. If he swaps 00 cam for the 01 cam, that should correct it right? I know it was discussed before, but I dont remember the specifics....
OutsiderZX12R
Street Racer
posted August 25, 2005 07:13 PM
Do you have any pics of this bike? I would really like to see them. That is the kinda bike I really like!
OutsiderZX12R
2000 ZX12R-A1
zxlnt
posted August 25, 2005 08:24 PM
I took some, but I am not sure what I did with them. I had them on my computer at one time. It wont be hard to get more. It's definately a feat of machining and some engineering. Pretty stealth looking unless you know what your looking for. Main give away is the big huge ass clutch cover. Everything else is pretty hidden..
12r1
posted August 25, 2005 08:31 PM
How the f....???
I gotta see that. That's just not right!
jeff
tuusinii
posted August 25, 2005 09:55 PM
There was just little time ago someone asking the same. You had to change the position of the cam sensor and in some year You even had to change the ignition rotor. Don't remember more.
RAC4IT
Bergie
posted August 26, 2005 05:02 AM
Do a search, this has been addressed many times.
posted August 26, 2005 06:28 AM
The ECU's are different between 00 & 01 if they were not, I could have saved $500 because I had an 01 at one time
zxlnt
posted August 26, 2005 06:35 AM
Bergie I did search before I asked. Search engine wasn't specific enough. And yeah vincent I know ECU are different..
outsiderzx12r
Street Racer
posted August 26, 2005 06:42 AM
If you get a chance to snap more pics of this bike I'd love to see them.
OutsiderZX12R
2000 ZX12R-A1
supra5677
posted August 28, 2005 03:22 PM
impressive that your buddy squeezed a 12 motor into a 6r.. Contact easyrider at ZX12R.org he knows about that stuff.
Brian
five 0
posted August 28, 2005 06:50 PM
You need to put the 00 cam in the 01 engine. It will run then.
5-0
trenace
posted August 28, 2005 09:19 PM
Damn, that's an outstanding project! If you can post more that would be great.
Actually, that is completely fucking outstanding!!!
ZXLNT
posted August 28, 2005 09:54 PM
Thanks Brian, thats what I thought but wasn't completely sure. Guys I'll try to get some pictures of it if he doesn't mind..
trenace
posted August 28, 2005 09:56 PM
If he could possibly explain really briefly what they key aspects are in doing this, what the pitfalls are, about how much is involved, that would be fantastic!
Awesome project for sure.
ZXLNT
posted August 28, 2005 10:39 PM
Lots frame welding and modification.
Custom Airbox
Bodywork modification
Custom front motor mounts
I believe the rear mounts lined up, but the engine mount bolts from the ZX12R wouldnt fit
correctly.
The speed sensor from the ZX6R isn't calibrated correctly for the ZX12R it reads way way way high when hooked to the ZX12R gauges..
trenace
posted August 28, 2005 10:44 PM
Oh... well that makes it an even more awesome project, but unfortunately one that I can't realistically see myself doing! The frame welding and modification, I'd have no hope of doing myself and wouldn't know where to go.
Amazing thing though. Has to be one hell of a bike to ride!
ninja12
posted August 29, 2005 08:23 AM
It's the exhaust cam sensor that's different.
Just grind the locator tip off and reposition it like the 2000.
The bolt will hold it in place since there are nothing to make it move.
Thanks to DM.
