BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Wrist Pin Sizing NEW TOPIC NEW POLL POST REPLY
gunner
posted August 25, 2005 12:19 PM
Wrist Pin Sizing
Who has the inside poop on why KHI put such a BIG pin in the 12? It's presents makes ring placement a bitch. Has anyone tried a smaller pin dia? Granted a new rod would be needed but that's not the end of the world.
spencercyclecom
posted August 25, 2005 01:47 PM
I have a set of new recondition stock rods...with 18mm piston pin bushing in them.(for sale).. you can run 18mm...thats what i have in the turbo 12....have you some pistons made with 18mm pins...and you can move the rings way down...
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
gunner
posted August 25, 2005 02:08 PM
This is what I'm currently doing. The rings need to be moved away from the Valve relief pocket once the pocket is made deeped for clearance issues with cams and certain degreeing numbers. I know it's very possible to downsize the pins, but WHY did Kawasaki make them so huge???? Is anyone having issues beating the pin Bosses out of the pistons?
posted August 25, 2005 02:26 PM
Gunner if you have the piston tops made .040 thicker and run a .063 Base Gasket, that will equal a 2 MM Smaller diameter Wrist pin! Does that cover it??
trenace
posted August 25, 2005 02:52 PM
While that is true, my objection to that, as opposed to referencing the piston tops to the same height, is that effectively that is shortening the rods (in the situation where one is having custom rods made.)
In other words, running the 19 mm wrist pin, I'm "entitled" to use up to 0.100" (is that crushed 0.100, or before crush?) while still using stock cam chain.
But running the 21 mm wrist pin but with the piston tops higher -- which in other words is saying dropping the center of the wrist pin posses lower -- then the first 0.063 of that, using your figure, or certainly at least the first 0.040", is lost due to the piston top being higher.
So, if the 19 mm pin will be strong enough, the piston pin bosses will hold up fine, etc then I would rather go that route, than run the 21 mm pin lower relative to the piston top.
238mph
posted August 25, 2005 03:10 PM
Not to mention lower reciprocating weight by using a smaller wrist pin
What did I win????
Pilot Powers took me to the grave, and brought me back...
  Ignore this member    Click here to visit 238mph's homepage.
gunner
posted August 25, 2005 03:12 PM
Thanks for your time Doug Ray.
posted August 25, 2005 03:45 PM
The larger the diameter allows thinner walls (about the same weight with a "Larger " Surface area to spread the load. I am running a .060 thicker top piston with a .080 Base Gasket. Top ring location is very improtant. Too high and the temp will hurt it. Too low and carbon build up can become a problem
trenace
posted August 25, 2005 04:02 PM        Edited By: trenace on 25 Aug 2005 17:02
True, all else being equal larger diameter is good. I expect Kawasaki did it by running the largest diameter they could with the valve cutouts they required and with the ring placement and ring / wrist pin relationship they wanted.
Cutting the valve pockets deeper then either requires moving the same diameter piston pin's center down equally, or reducing the wrist pin radius equally. So that is the issue currently being faced.
I don't myself like the idea of moving the wrist pin center down relative to the valve cutouts. If the rod length were already plenty then I would be fine with it, but it's already minimized as is.
posted August 26, 2005 06:33 AM
How much "MORE" valve relief do you require? If you are raising the compression then the taller dome will keep the same reilef if you need more than .050, then that is a lot!. I would think that if someone is making pistons that they would want at all costs to make something that could be used on "Stock" Rods so that it or a similar design could be used for other pistons
gunner
posted August 26, 2005 08:13 AM        Edited By: gunner on 26 Aug 2005 09:28
Vince..........The man is going to make them both ways
posted August 26, 2005 08:24 AM
PERFECT!
trenace
posted August 26, 2005 11:04 AM        Edited By: trenace on 26 Aug 2005 12:07
I was going to be using custom rods anyway as I wanted to get the length a little longer, in addition of course to wanting the weight savings.
Fortunately, I had not placed the order yet!
It does look as if those keeping stock rods and getting the other version of these pistons will have to run an extra mm of base plate (if I understand correctly) than they otherwise would, to compensate for the wrist pin sitting a mm lower, enabling the deeper valve cutouts and a little more space for the rings and a little thicker top.
posted August 26, 2005 11:48 AM
Talking and communicating
posted August 28, 2005 03:32 AM        Edited By: entropy on 28 Aug 2005 04:34
... Is anyone having issues beating the pin Bosses out of the pistons?
yep, i sure was; with 87mm pistons, NA, 15:1+ CR.
Noonan opened up the pin/boss clearance just a titch and that may have cured it.
Anyone who is having to press the pins out should look CAREFULLY for galling on the pins and scoring on the bosses...
rather than re-invent the wheel have you called Noonan, told him yr project and asked his advice??? This is what JE (and others) do for a living, eh?
(VH: pls don't go on an "anti-JE tirade". As near as I can tell, yr experience was a singular point...)
gunner:
VERY cool thread, thanks for starting it!!!! :thumbsup:
posted August 28, 2005 04:23 AM
I took this tool
And made this tool out of it.
So I could use it for this on these pistons when I hav a tight Pin.
One of the aformentioned JE Pistons
I also do not like the quality fit or finish of the COmetic Gasket also and they charge a Ton for Base Spacers that you can get from Falicon for about 1/2 to 1/3 the price! The Comet had very unfinished rough edges and that takes a while to smooth out
gunner
posted August 28, 2005 08:18 AM
Entropy.......What size pins do you run in your pistons? Stock or something else?
posted August 28, 2005 04:12 PM        Edited By: entropy on 29 Aug 2005 04:59
VH,
judging from the pix, yr pin & prolly piston is fukked...
PS: no quench ring on those JE pistons????...
gunner,
.my pin size is stock
aliveagain
posted August 28, 2005 05:35 PM
VH,I thought you said you wouldn't use cometic?
gunner
posted August 28, 2005 06:57 PM
Where else can you get a Head Gasket besides Cometic?
posted August 29, 2005 03:54 AM
the question for me is: WHY go to anyone else than Cometic? Solid products, great service.
posted August 29, 2005 04:56 AM
What do you think got me to that decision??
The Stock is better than the Cometic. "IF" I were to need a larger opening, I would modify the stock to fit. removing 1 mm in diameter is not that difficult.
Quench Ring? ENT
The piston had a groove in the side to help with the pressure
The Wrist Pin and Piston were the stock items and I always run Crocus cloth through the Rod Small in to polish it out.
posted August 29, 2005 11:41 AM
Vincent,
Is that work bench or a junkyard? :-)
posted August 29, 2005 04:38 PM
Vincent,
OK Paul Sr. No, but if I remember right, it was about the 2nd week of working all night and at that point where ever the tool leaves my hand is where it stays until I get the engine hoisted off the bench so I can "Carefully" clean and put away all my tools are parts for the Next venture of putting the engine in the frame.
I always start out with everything clean and put away (Otherwise I would not feel inclined to start ) Worst part is I also do not trust anyone to touch anything because they may not put it in the same place and it will be lost forever.
BTW, I remember a scene in Gainesville where "Things" were not so neat but the Job sure got done in a Hurry I am glad that you still take the time to visit here. How are you doing?
0.41874098777771 seconds processing time
