wheelieking
posted August 24, 2005 06:22 PM
motor oil
I know this has been probably covered before but which weight of synthetic should I use. I live in Florida if that helps. 2nd question...Is motul 300.. a specific weight or is there multiple weights in the motul 300?
trenace
posted August 24, 2005 06:32 PM
Edited By: trenace on 24 Aug 2005 19:41
There are several weights available.
Cheapest price I found is $10.75/liter for 15W/50 at http://www.oneidasuzuki.com/store/customer/product.php?productid=17709&cat=691&page=1
A hot weight of 50 is probably overkill IMO, but oh well. The slight power loss (doubt it is more than a couple of hp, or possibly not more than 1 hp if compared to 40 weight) from increased pumping losses and increased drag might be undesirable for say 1/4 mile or land speed racing compared to a lighter weight.
However, only a couple bucks extra per liter for these 2 liter bottles in different weights from http://www.ltbmotorsport.com/moraoil30.html
I didn't answer your question on weights to use because I have no evidence whatsoever that there either would be be a risk or less durability from say a hot weight of 30, or would not be. Don't know if anyone has. That would probably take a LOT of endurance testing specific to a given motor, unless there are obvious multitude that's been compiled of in-service examples of clearly greater failure rate with some given light weight. Is there?
wheelieking
posted August 24, 2005 06:57 PM
so a 30 or 40 weight will improve performance slightly... because they are thinner right?
I am looking for maximum performance with durability as well
trenace
posted August 24, 2005 07:18 PM
Yes, comparing 40 weight (I'm referring to the higher number, for example calling 10W-40 "forty weight") to I think 15 weight, Sport Rider magazine found about 3 hp.
So as a guess, each reduction of 10 weight is worth no more than 1 hp.
At some point, I'm just not sure anyone knows exactly where it is for most specific motors including the 12R motor, reliability is compromised. Will 30 weight increase the risk of throwing a rod? I don't know.
At least briefly, it can be possible to run zero weight without blowing the motor. But long term it doesn't seem like anyone is advising it.
238mph
posted August 24, 2005 08:16 PM
For what it's worth, I ride mile long wheelies on my 12, and so I run a thicker oil, 30 weight,
to be sure that I have protection in case I suck air on occassion while having the front
end up high...
If you wheelie your 12 for long distances, I suggest you run a thick oil with any of
the sticky additives...
Jere
PS if you don't wheelie long distance, you need to change your screen name!!!
Pilot Powers took me to the grave, and brought me back...
trenace
posted August 24, 2005 08:31 PM
30 is thicker than 20 or 15... but thinner than the usual 40 or 50!
(just wondering if maybe that was a typo?)
238mph
posted August 24, 2005 10:31 PM
I run straight 30, which always stays at 30... 10-40 or 20-50 vary with their temp...
But I can tell you I have tested this... heat up some 20-50 and pour it... then heat some
straight 30 weight and pour that... you can SEE it's much thicker in the pour.
But in really cold weather, 30 weight is too thick... I live in AZ so I don't have that problem.
trenace
posted August 24, 2005 10:33 PM
I understand now! I wondered if that was it but could not be sure without asking.
You're right, while I haven't ever done that with straight 30 weight vs multigrade 30, I have seen it with straight 40 weight. I don't know why that is, from the criteria you would think that should not be so but it is!
tuusinii
posted August 24, 2005 10:50 PM
Use what the book recommends 10W40 - 20W50. Can't go wrong with that. I remember a test on different oils 1-2 years ago in German magazine (Motorrad). They had 2 bikes - Busa and SV650. Three different oils. Not sure about the makes but I think it was Mobil 10W40 full syn for bikes, Castrol GP 20W50 mineral for bikes and some no brand 10W40 (well the brand was probably one of those that big German bike apparel shops (Louis, Polo, Hein Gericke) sell). The most HP was made with the Castrol GP, and least with no brand. But the difference was in less than 1 HP so in reality that goes to the differences in the measurement and You can't say wich gave more or less HPs. I really wouldn't go to straight anything or below 40 - especially in hot climate like Florida. I use 20W50 even in Finland and my bikes seem to last long. In Florida climate I would go to 50 weight just for the extra peace of mind - and that really dosen't take You HP:s away - at least not so that You could tell the difference.
tuusinii
posted August 24, 2005 11:02 PM
quote: I understand now! I wondered if that was it but could not be sure without asking.
It depends about the temperature in wich the oil is in. The straight 30 is thicker until You hit the specified temperature wich is 100 C(212F). Remember thats what the multigrade means!
trenace
posted August 24, 2005 11:04 PM
Edited By: trenace on 25 Aug 2005 00:06
It is possible that I did not have it hot enough when I tried my informal test, just heated it on the stove to what was pretty close to boiling hot, and the straight 40 was nonetheless plainly more viscous than 10W-40.
Now that I have a thermostatically-controlled hot plate I could do it more formally and at precisely 100 degrees C, and for example have the oil drain through a small hole from a given container and time the emptying rate as the indicator of viscosity.
238mph
posted August 25, 2005 06:43 AM
Edited By: 238mph on 25 Aug 2005 07:51
I don't care what temp you do it at, the straight weight will always be thicker.
I also know Tuu that it doesn't make more HP... but it does give better protection for
oil starvation while doing long wheelies. That;s the only reason I run it...
I've never lost a main bearing doing long wheelies (lots of other guys have)
Tren, yes, it sort of defies what the say... but think about... 10-40 means that in cold
weather it acts thin like 10 weight to let your motor crank easier, but when it's hot
the oil acts like 40 weight to give you thick protection... sounds great right???
Show me any oil that does just the opposite of what physics rules do... when it's cold,
it will be thicker, and when it gets hot, it thins out... I was always amazed that they got
away with selling this idea...
Jere
posted August 25, 2005 06:53 AM
Good reading here and one other thing to consider 300V is more for Racing than Street. remember on the Street, there is a lot of stop and go not to mention the heating and cooling of the Oil. Motul e-tech 100 (to me) is better at both not to mention about 4 to $5.00 cheaper a quart! (I use straight 30 weight in my Old Van and 10 w 40 in my Old Car but when it is time to inspect them emissions, I put in 20 w50 and have found that the idle is lower and a lose a few MPG
psycho1122
posted August 25, 2005 08:47 AM
It would be pretty hard to cavitate the oiling system on the 12 doing "Mile Long Weelies" due to the design of the oil pan and location of the pickup. NOW... if you run your oil level low for some reason... you may not retain enough oil in the pan at high rpm's. Most of the oil will be hung up in the rest of the engine.
trenace
posted August 25, 2005 08:51 AM
Hmm, from that standpoing (oil being hung up in the rest of the engine, lowering levels in the pan) higher viscosity oil actually would be worse, while a multigrade 30 would be better (in that regard.)
psycho1122
posted August 25, 2005 08:57 AM
How about just running the right amount of oil in the engine.....
I use Mobil 15w50 at the upper part of my oil window. NO power Loss and NO ISSUES.
psycho1122
posted August 25, 2005 08:58 AM
The Mobil flows like water at operating temperatures to boot!
trenace
posted August 25, 2005 09:05 AM
Definitely on the right level amount.
Or possibly I even run too much... I run it to where there is only just the slightest trace of air visible at the top of the window.
blueford
posted August 25, 2005 09:29 AM
I use 15-50 Mobil 1 auto to top and a little over the site glass in a place that routinely hits 115 degrees, but realistically maybe running your engine on a frequent basis is the single most important factor in engine health?
And Jere if you're serious, mile long wheelies are crazy
238mph
posted August 25, 2005 10:14 AM
Edited By: 238mph on 25 Aug 2005 11:21
I always fill to the top.... and the point of the long wheeleis is that at nearly
the 12 oclock position, you are "rocking" back and forth all the time... which
sort of tosses the oil up and down and CAN cavitate some air into the oil.
Also my point of the thicker oil, with sticky adds, is so that even if I lose oil pressure
for awhile, the protective film stays on the bearings rather than rinse off like a thinner
oil...
Now I didn't want this to turn into a pissing match, just my opinion, and it has worked
for me for years.
Run your thin oil, ride highway wheelies for 10-15 minutes on the back wheel, and see
how long your main bearings hold out... ah, Blitz, didn't you have to replace some?????
238mph
posted August 25, 2005 10:19 AM
Edited By: 238mph on 25 Aug 2005 11:20
Here's a pic of the height we ride 'em....
psycho1122
posted August 25, 2005 10:32 AM
238...
Come on up and ride with us (head out from Mesa AZ)some Sunday AM.....
I do wheelie my 12 down the freeway at times, I would LOVE to see you come up and do it for us!
BTW.....That is not you on a 12R in the pic. Do you have one of yourself??
238mph
posted August 25, 2005 11:55 AM
I'm down in Tucson!!! sure, I'd love to hang with you guys some time...
I did a ride a few weeks ago up to Salt River Canyon, (Ithink that;s what it was called)
and we had a great time, although I don't like to ride fast on roads I don't know, and these
guys were balls to the walls... I ride hard but I have to know the road to feel comfortable.
In the pic above, that's George on his Zuke... I posted to show the height we get doing
wheelies vs a power wheelie which isn't nearly as high....
George is amazing in that he can do circles...
I'm working on them but I'm no good at them yet... I'm going to add a 12 bar if I keep
doing the slow stuff... I was going to buy a 600 and set it up for stunting, but I do love
the 12... however it's too twitchy for slow work... too much power even at idle...
Also, I wear gear when I ride, no matter how hot... no more road rash for me... got tired of
it big time I don't have any good shots of me doing wheelies, burnouts, nothing.
Guys typically don't carry cameras...
wheelieking
posted August 25, 2005 07:01 PM
thanks for the info...good stuff
I went ahead and bought kawi full synthetic 10-40.. I noticed on the back that it is made by Motul.
tuusinii
posted August 25, 2005 10:00 PM
Edited By: tuusinii on 25 Aug 2005 23:11
quote: I don't care what temp you do it at, the straight weight will always be thicker.
Jere
Of course every oil will be thinner when it's hots. The - for example 10W40 - multigrade oil dosen't mean that it will be thickier when it gets hot. It means that in 0 degrees celsius (32F) it will be as thick or thin as a straight 10 weight. And in 100 degrees C (212F) it will be as thick as a straight 40 weight. Of course it will thinner when it gets hot but it won't be as thin as a straight 10! In the reality the oil dosen't have different weights. It has one weight and onve viscosity index wich tells how the viscosity changes with temperature. Weights are just different categories of the real viscocity and same weight oils can have little different viscosity in certain range. Multigrade oils just have a different viscosity index than old straigth weight oils - so it acts like multigrade oil. When using straight 30 weight You can probably get away with it if the temperature never gets really cold or hot. Because in when starting in cold the 30 weight just is too thick and dosen't get to the motor as fast as a thinnier oil would - and so leaving the motor without protection. In very hot it is still too thin because the motor was designed to use 40 or 50 weight.
