BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Airfilter test NEW TOPIC NEW POLL POST REPLY
tuusinii
posted August 22, 2005 10:19 PM
Airfilter test
Well this is not exactly about motorcycles but all engines use airfilters. In this test they have different airfilters on GM engine. They have all the avaivable filters - some paper some oiled like K&N. Here is the test:http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm The verdict of the test is that the better the filter flows the worse is the filtering. So K&N flowed best but also filtered the least! Also the oiled types - like K&N - went "full" earlier than the paper types. So it seems that You can't have it all!
frEEk
posted August 22, 2005 11:44 PM
there's a shocker
good link, thx.
rac4it
Bergie
posted August 23, 2005 08:52 AM
screens rule
MAXIMUS
posted August 27, 2005 08:57 AM
Its almost better to keep the OEM filter then install the K&N when you want the performance. I have noticed that when i run my K&N all the time when i change my oil i have gritty feeling in it. So i installed my original filters and when i performed the following oil change the grit was gone. the grit did not contain any type of metal fibers, just looked like dirt. Im sure it was now that its all gone.
0.33201885223389 seconds processing time
