BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Chain alignment tool -- pretty good, recommended NEW TOPIC NEW POLL POST REPLY
trenace
posted August 22, 2005 02:28 PM        Edited By: trenace on 22 Aug 2005 16:08
I just got in a Project One chain (wheel) alignment tool, $35.
http://www.project-one.us/motorcycle.html
Now, my wheels were already aligned by string. I just attached this thing to the sprocket -- on the underside rather than the top as I didn't want to bother removing the hugger -- and sure enough the rod lined up so far as you could tell perfectly with the chain.
Actually it was much better than their picture:
In their picture, unless you could get a direct overhead view, because of the rod starting out so far away from the chain and because of dirtbike chain sag, it's hard to be sure the relationship is the same there as at the far end. However in my case it was way closer, so much so that only a couple of inches from the sprocket, pushing the chain up just a little had it touching the tool.
There is argument by the proponents of this method that string alignment isn't as accurate because the sidewalls of tires have their own error and so unless you do string alingment on bare wheels, it's not as good as that. I myself don't buy that, personally I will continue using string alignment to get it what I consider "nailed" or to verify that it is, BUT this thing is way faster and what I will use it for is for the initial adjustment, which should now be super fast.
And then if the string agrees it's bang-on, I'm done... or if the string suggests tweaking it I will do so. However, for ordinary purposes this thing alone no doubt is "close enough" and a pretty good item I think.
scooter trash
posted August 22, 2005 03:19 PM
Silly me, I've been using a laser level for over a year. LOL
Its small, too.
extreem
posted August 22, 2005 07:24 PM
These things have been available for years........Aligning the chain does not ensure the axle is aligned to the chassis. Better than nothing I agree, but I'de rather see Project One build an axle alignment tool.
trenace
posted August 22, 2005 07:47 PM        Edited By: trenace on 22 Aug 2005 20:50
Oh, this was the first I'd seen one that seemed solidly built and non-flexy, I'd seen a couple before that were similar in concept but shorter and flimsier. Which isn't to say that they all must be.
ST, I've thought about using a laser level but hadn't ever got around to rigging how to do it, seemed simpler to just keep using string rather than work that out
Whereas this, it was just click Paypal, watch $35 bucks disappear, get item in mail that I think will wind up speeding up the string jobs since the first approximation with this tool may even prove right, or if not will at least have me real close.
If it saves 10 minutes off the string method each time, it's worth it... also I was thinking when posting it that there are guys that do not use the string method at all. For them, while I would still recommend string (or if I had it worked out, your laser method), this seems more than good enough to beat the "by guess and by God" method or the marks-on-swingarm method and so this could be a good help for them.
trenace
posted August 22, 2005 07:57 PM        Edited By: trenace on 22 Aug 2005 20:59
You know, I had thought a little about the laser before but had not figured it out, as I assumed I would not be able to see the beam (my garage not being dusty), and couldn't figure where I was going to project the spots to. So I decided not to bother.
Can you tell me if I've figured it out now? Seems pretty obvious this time: just put a ruler, square, whatever against the tire (front and back, left and right) and then see where the laser spot touches the measuing device! D'oh!!!!!
Is that it??
238mph
posted August 22, 2005 08:46 PM        Edited By: 238mph on 22 Aug 2005 21:50
Hey Tren, since when do you run knobbies on your 12??
  Ignore this member    Click here to visit 238mph's homepage.
trenace
posted August 22, 2005 09:18 PM        Edited By: trenace on 22 Aug 2005 22:25
Not ever!
Though I'm interested in what frEEk finds from doing it!
If not for having such strong distaste for the idea of dropping it, I actually would find considerable appeal in the idea of trying dual sport tires on limerock roads or whatever. But I'm not going to, got a stupormoto instead.
posted August 23, 2005 03:42 AM
done the string-thing for years = PITA
had one of these rod things = didn't like it
did the laser thing = anyone wanna buy it?
got the Muzzy tool = best!
posted August 23, 2005 03:46 AM
Like I said on LaBusas..... too bad Dino dont market his little wheel alignment deal. Its nice! Hint hint....
eastbaydave
posted August 23, 2005 03:57 AM
if it don't wobble.....it's straight....:P
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
vozizm
Got Nothing Witty To Say
posted August 23, 2005 04:02 AM
Dino..lets see a pic of said tool?
VOZ
posted August 23, 2005 07:34 AM
Dont bother Dino...he's ridding a Lazy boy these days.
osti33
posted August 23, 2005 10:35 AM
Couldn't agree more. I have the Muzzy tool as well. It is really nice.
trenace
posted August 23, 2005 01:15 PM
It seems to me (just from what seems to make sense) that once one knows a bike is straight when the Muzzy tool says so -- in other words when the string test shows it's straight and the Muzzy tool agrees -- then one need only use the Muzzy tool from that point on.
But, failing ever to do the string test, the Muzzy tool would prove only that the axle is centered in the swingarm. But if the swingarm pivot is a trace off of true, then the bike would be a trace off, so the Muzzy tool as the only test ever done on the bike doesn't seem to prove overall straightness.
scooter trash
posted August 23, 2005 03:07 PM
Is that it??
Six and a half dozen of the other on the method I suppose. I'd shoot some pics of my method but the swingarm is off now.
Gimme two weeks. Everything is going to the powder coaters tomorrow.
posted August 23, 2005 03:27 PM
GMD offers the sweet numbers service if you really wanna be anal about it.
The Muzzy tool is $150+ now.
The idea of the Muzzy tool is to assure the rear wheel is straight. With production bikes there is always gonna be some tolerance problems.
osti33
posted August 23, 2005 03:33 PM        Edited By: osti33 on 23 Aug 2005 16:34
edit.
posted August 24, 2005 11:31 AM
i sure am not gonna get into this discussion again (absolute alignment vs Muzzy/swing arm alignment); here is an observation.
I did the string method for years (since 1964 on my Duc 350) and swore by it.
I can feel even a small bit of miss-alignmenmt in my wrists while going down the highway, one arm feels just a tad longer than the other. I betcha you fellers can feel the same thing
The string method often left me with a tiny bit of long arm, the Muzzy NEVER does.
Additionally, when I am fine tuning the chain tension for drags, the Muzzy is manna from heaven.
About the rod thing or the laser thing????? fuggitabout it unless long arm doesn't bother you.
IMHO
jus1975
posted August 24, 2005 02:44 PM
You mean to tell me that as much as the laser alignment tools are they are no good. I was very close to buying one.
238mph
posted August 24, 2005 02:48 PM
If you want to have some fun, setup the rear end deliberately off to one side or
the other... you'll find that if you suck turning to the right, you can fix it by using some
alignment to help you...
Pilot Powers took me to the grave, and brought me back...
ozzy
need guberment cheese
posted August 24, 2005 04:13 PM
I made a tool that aligns the axle to the swing arm that works well.
trenace
posted August 24, 2005 04:18 PM
While that wouldn't work for me or at least I don't guess it would, that makes me wonder if perhaps in road-racing an absolute trace of such "misalignment" might not actually make sense given that the courses are not symmetrical, there may be one or two given turns that are really critical to the overall lap time, and often the tires will go out on one side before the other.
Obviously I'm not talking about anything big, just a trace.
Wonder if any teams fool with that, see if they get an extra tenth of a sec per lap with such a thing?
scooter trash
posted August 24, 2005 04:54 PM
I'm not going to get in a pissing match here, but I assure you my chain is very, very straight.
I can take pics of the sprocket wear and stuff if it would help. ;-)
14K miles and my sprockets and chain are happy. Very happy.
Bigsaint
posted August 24, 2005 09:12 PM
And here I thought I was on the cutting edge using a tape measure, only to see scooter has a damn laser
vozizm
posted August 25, 2005 09:50 AM
Like Entropy i have that one arm longer than the other syndrome also!!
VOZ
0.2402081489563 seconds processing time
