mo
posted February 26, 2002 05:27 AM
a little oil info
Motorcycle Motor Oil
by Mike Guillory
This article was written by Mike Guillory and he has graciously allowed me to post it here. I think it is offers an excellent perspective and discussion on oil! It certainly has helped to shape my opinion on this complex subject. And to frequent visitors, this article was updated in October 2000.
Brief Introduction
Along with keeping things adjusted properly, using a good quality motor oil and changing it regularly is the key ingredient to keeping your motorcycle running for a long time. At the bottom of this article is an addendum which lists current non-energy conserving SJ oils which may be suitable for our motorcycles.
Price of Motor Oil
So how do you make an intelligent choice? Will $1.00 a quart automotive oil work OK or do you need to pay $4 to $12 a quart for "motorcycle" oil? You have to answer that question yourself, but here are a few facts to help you make the best decision for your situation.
The owner's manual of your modern motorcycle will say something very similar to the following:
"Use only high detergent, premium quality motor oil certified to meet API Service Classification SF or SG (shown on container). The use of additives is unnecessary and will only increase operating expenses. Do not use oils with graphite or molybdenum additives as they may adversely affect clutch operation."
That's pretty clear. But what do you do since all automotive oils now say on the container "meets SJ Service?" That's easy! By consensus of the API and the manufacturers, the current SJ classification meet all requirements of SF, SG, and SH, plus all earlier API gasoline categories. The current SJ actually offers some additional benefits over the older classifications. So, if the motorcycle requirement says "SG", be confident that "SJ" indeed meets that requirement.
Real World Test Results
Are there any "real world" examples of long motorcycle engine life using automotive oils? There's a good one in the June 1996 issue of Sport Rider magazine in a report called the "100,000 mile Honda CBR900RR." The owner used conventional Castrol GTX oil, 10W40 in the winter, 20W50 in the summer. He changed it every 4,000 miles, changing the filter every OTHER oil change. No valve clearance adjustments were required after the initial one at 16,000 miles. And a dyno test against the same model with only 6,722 miles showed torque and horsepower virtually identical. The 100,000 mile bike was even used for some racing. In a subsequent follow-up, the same CBR had passed 200,000 miles and was still going strong!
A Little Technical Discussion
Some have incorrectly said the newest SJ oils (all automotive oils are required to meet SJ Service classification) no longer contain zinc and phosphorous additives which protect against wear. The truth is, the levels of these additives have a limit, but the limit is high enough to offer premium levels of protection in gasoline-powered motors, including our motorcycle engines.
Some are concerned that the new "energy-conserving" motor oils may have "friction modifiers" which will cause clutch slippage. Many motorcyclists, this author included, have used these energy-conserving oils with no clutch slippage. However, increasingly there are reports that these oils are causing clutch slippage and starter engagement problems in some motorcycles. Therefore, it is best to use only "SJ" oils which are *not* "energy-conserving." Read the back of the container. It clearly identifies this. All 5w50, 10w40, 15w40, 15w50, and 20w50 oils which I have found are *not* energy-conserving and can be strongly recommended for general motorcycle use. Conversely, all 0w30, 5w30, and 10w30 oils I found *were* energy-conserving, as required by the USA government.
What about synthetic vs semi-synthetic vs "dino" oils? All motor oils have several special additives formulated into the oil to protect from corrosion and wear, plus detergents to keep combustion products in the oil. For normal (non-extreme) use, "dino" oils protect as well as the synthetic oils. However, if you plan to race, or run at extremely high temperatures, or plan to extend oil-change intervals, or simply want the best, then a synthetic or semi-synthetic may be your best choice.
Frequency Asked Questions
What is a reasonable oil-change interval?
Most manuals recommend not to exceed 8,000 miles after break-in. But short-trip riding is considered severe service and the most common oil change interval is 3,000 to 4,000 miles. However, a long trip is the easiest service for the oil and going 6,000 to 8,000 miles between changes while on a cross-country ride is routine. Also, the use of synthetic oils can easily double the oil-change interval.
Will changing the oil even more frequently, like every 1,000 miles, prolong the life of the engine?
Not very likely, because even at 3,000 to 4,000 miles, the oil and additives are not degraded very much. Changing more often just wastes money.
What about the claims that motorcycle-specific oils contain "special polymers which are resistant to breakdown caused by motorcycle transmissions?"
There are no such polymers. Oils often require the addition of polymers to create a multi-viscosity oil, like 10W-40. Whether it is a motorcycle oil or an automotive oil, all polymers are subject to some degradation in the transmission. If this bothers you alot, use a synthetic oil. Synthetic oils require little or no polymer, so viscosity change is very small.
Why are motorcycle oils so much more expensive than automotive oils?
Cost of doing business is higher per quart of motorcycle oil. Large oil companies make so much more product that their profit margin per quart does not have to be so high. Some motorcycle oils may actually offer less protection than SJ automotive oils.
What about the claims by specialty motorcycle oil manufacturers, that their oil is better?
That's a good one. Next time you hear that line, simply ask, "What evidence do you have?" Chances are, there is no evidence. If you do get any, please let me know!
Now, armed with all this information, you are ready to make your choice between automotive oil and motorcycle oil. Either will work fine. Your motorcycle probably cannot tell any difference. There are many riders, the author included, who use nothing but good quality automotive motor oils. There also are many who use nothing but motorcycle oils. All indications are that both choices work equally well, because motorcycle engines are designed so well that the oil really doesn't make any measurable difference. As long as it meets SG, SH, or SJ Service requirements.
Addendum
In the past year or so, some notes went around regarding several independent studies that showed "automotive" SJ oil that *is not* energy-conserving (EC) works just as well as motorcycle-specific oil, and in many cases better. So, I decided to compile a current list of oils that meet this requirement in my part of the country. Hopefully it will help some of you find these oils, if you want to use them. They are listed alphabetically. All should work well for motorcycles.
Conventional Oil ('dino') - 10w40 and 20w50
Castrol GTX 10w40; 20w50
Chevron Supreme 10w40; 20w50
Exxon Superflo 10w40;20w50
Mobil 10w40; 20w50
Pennzoil 10w40; 20w50
Quaker State 10w40; 20w50
Texaco Havoline 10w40, 20w50
Valvoline 10w40; 20w50
Valvoline VR1 Racing 20w50
Heavy-Duty Oils
The following are all 15w40 oils which, by industry convention, are formulated for both diesel and gasoline engines, designated as API CH-4 and SJ. These offer the highest levels of protection and are among the best general-purpose oils for motorcycles.
Castrol RX Super 15w40
Chevron Delo 400 15w40
Mobil Delvac 1300 Super 15w40
Pennzoil Long-Life 15w40
Quaker State 4X4 Synthetic Blend 15w40
Shell Rotella-T 15w40 (my personal favorite)
Castrol Syntec Blend Truck and 4X4 15w40
Synthetic Blends (see notes below) - 10w40 and 20w50
Castrol Syntec Blend 20w50
Quaker State 4X4 Synthetic Blend 10w40
Valvoline Durablend 10w40; 20w50
Full Synthetics - for Maximum Protection
Castrol Syntec 5w50
Mobil 1 15w50 (a popular choice)
Pennzoil Performax 100 5w50
Valvoline Synpower 20w50
Notes: These are all the major brand non-EC oils I find at my Houston-area auto-supply stores. Different parts of the country will have a different subset.
Regarding synthetic "blends". These blends typically contain about 25% to 30% synthetic base. It is not clear that they offer measurable benefit over a 100% 'dino' oil. But they also don't cost much more.
Important Note: Be sure and use the recommended viscosity range, e.g. 10w40, 20w50, etc.. for the climate in your area. In general, to protect your motor, use the 'heaviest' oil you can that still meets the manufacturer's guidelines. For example, 20w50 is better in warm weather than 10w40, because it gives you a thicker oil cushion between bearing surfaces at operating temperature. For racing, a thinner oil will offer less resistance and thus more power, but will offer less protection.
I personally believe in these oils and use nothing else in my motorcycles. As always, you have to make your own, informed decisions.
A Note on Warranties
Since it is generally accepted within the industry that current classifications also meet all older ones, there can legally be no warranty issue. In fact, some of the oils above, like Pennzoil and Havoline, actually say on the package "SG" in addition to SH and SJ.
And, finally, it is gratifying to have received so many emails the past 15 months from motorcyclists finding this oil and oil filter information useful to them. I am just happy to help, and I plan further updates, but only when things change significantly. Please refer to Oil Filter Alternatives - Honda Motorcycles also by Mike Guillory for a comprehensive review of various oil filters.
Web Master's Note
The author is a Chemist, retired from a major Oil and Chemical Company, after a career in the Quality Assurance of Fuels, Lubricants, and Chemical products. He and his wife both ride.
Mike in Houston
'94 VFR750 "XENA"
'85 V65 Magna "YELLOW SONIA"
Technical Corner | Main Garage
KW
kzz1
"Show me whatcha workin with"
posted February 26, 2002 12:42 PM
Never use motorcycle oils!
Since I been riding motorcycles even our current rides with over 10,000+ miles, I use Mobil One 15/50 wt car oil and change every 3000 miles. Motorcycle oils IMO is a waste of money!
hondo
posted March 05, 2002 02:03 PM
Shell Rotella-T for me also!
ROCKET J
Goes to water over a dummy!!!
posted March 06, 2002 10:02 PM
Just wondering...
Why do ALL the highline cars come with and recommend synthetics?
Rocket
If I get any smarter, my head will explode!
ZXtra
posted March 07, 2002 02:20 AM
Why???
quote: Why do ALL the highline cars come with and recommend synthetics?
Rocket
Synthetics provide the best lubrication, but costs more. So you don't get it in "lowline" (cheap) cars. -ZXtra
ROCKET J
posted March 07, 2002 02:25 AM
Thank you, ZXtra
My point exactly.
Rocket
