BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Anyone have an extra 12R piston? (Needed for CP pistons as pattern) NEW TOPIC NEW POLL POST REPLY
trenace
posted August 03, 2005 03:58 PM
Does anyone have an extra 12R piston that they could send to CP pistons, to help them create a pattern for making 12R pistons?
I would gladly send $15 or $20 or whatever you think fair for postage and your trouble in sending it off.
Both Gunner and I are having CP make pistons for us, but I am having to send them a head so they can digitally map the combustion chamber, but I don't have a piston to send them and neither does Gunner.
Thanks!!
osti33
posted August 03, 2005 04:02 PM
I've got a bunch. What is the address??
trenace
posted August 03, 2005 04:10 PM        Edited By: trenace on 3 Aug 2005 17:10
Help in less than 240 seconds!!
That is outstanding! Thank you very much!!
(Would have been outstanding even if not so fast!)
CP Pistons
1902 McGaw Avenue
Irvine, CA 92614
Attention: Scott
Also important to label that it's a ZX-12R piston.
Please PM me so I can reimburse you for the shipping!
Very much appreciated!
posted August 03, 2005 04:14 PM
Why do they need "Another" Piston? In June 2004 and September 2004 they had the pistons and after an error in the Valve pocket made a great set of Pistons for me. WHO are you talking to out there? I still have the Build information on the set they made for me. You may want Higher compression that I had and less Dome thickness (Mine is .060 thicker). The do make Excellent pistons and are one of the few places Mahle mentioned as Competition
Note the Decal and how many there are not
osti33
posted August 03, 2005 04:15 PM
I'll send it out tomorrow morning. I'll PM you after I ship it to let you know what it cost. Is ground shipping ok or do you need it there faster? Ground shipping from me to Cali is about 4-5 business days.
gunner
posted August 03, 2005 05:48 PM
Vince, we're dealing with a guy named Scott at CP. When I first talked to them about doing this he said great because he wants to stock pistons for the 12 and he needed a head to pattern the dome from. I mentioned to him that they had already done some pistons for you in the past and I figured that they shoud already have what they needed to build more.He informed me that because your's were low compression he wasn't too worried about the dome shape too much because he had a little extra fudge margin, but for a high compression set he wanted to digitize the chamber and make the best damn piston out there anywhere!!!! I said great!!!!!!!!!! Hopefully we'll all have a new source for some great pistons in the near future. I'm thankful that Trenace has a spare head for this project. Thanks T..................
trenace
posted August 03, 2005 07:37 PM        Edited By: trenace on 3 Aug 2005 20:39
Actually Osti if you could send it Priority (2-day) that would be much appreciated!
From what Scott told me, he was not sure as to exactly when they will be digitizing things but quite likely the sooner they get the head and piston, the sooner the new pistons will be done.
Thanks!
osti33
posted August 03, 2005 07:45 PM
2-day it is.
posted August 04, 2005 07:28 AM
PERFECT! You know who these guys are?? They are mostly EX Employeed of JE & their Owner Wiseco Pistons that were not happy with the quality of what was being made. Remember when I found that the Valve pocket angle was bad at 2 AM I sent them a note and they responded at 7 AM their time and had new pistons to me in less than a week. I have had "ZERO" or less problems with what they made for me and believe me I have put them through the rack! I would not buy any other type of piston
trenace
posted August 04, 2005 10:31 AM
Also, does anyone know whether the JE pistons use deeper relief for the valve cutouts?
Or in other words, whether deeper reliefs are a good idea if using say a Muzzy cam? (Because if the JE only have stock relief, then stock relief I would think would be adequate.)
Thanks!
spencercyclecom
posted August 04, 2005 11:25 AM
CP makes some good pistons...BUT you are going through alot of trouble...when JE will make you whatever you want and they dont have to have a head sent int to them. Think about it.
A piston manufacturer should already have a head scanned of the most popular bikes....and not be asking potential customers to do it for them...whats gonna happen when a head gets lost in the mail....CP gonna pay for it????????????
CP pistons cost more than JE Pistons about the same as a JE "custom piston" which is more than a off the shelf JE Piston.
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
osti33
posted August 04, 2005 12:26 PM
Piston is in the mail.
osti33
Trenace I'll PM you the info.
osti33
posted August 04, 2005 12:33 PM
PM sent.
osti33
posted August 04, 2005 12:34 PM
This seems like a very good point Doug.
posted August 04, 2005 12:45 PM
when fishing sometimes it is good to throw the line over the other side of the boat......
Thanks!
I do not know what relief measurements JE uses, but the Centering of the valve pocket and the depth on Mine were off and caused a Valve to touch the piston in 1 cylinder and none of the others. The valves were all adjusted within .002 of each other and the measurement I got for the Cylinder I measured was either .040 or .060. The problem was, the pockets I measured varied as much as .015 which is .030 difference. When Bear Blew up his engine at the first Gainesville he attended, upon careful examination by some very serious Tuners, they pointed out that the Valve were touching the Piston Valve Reliefs on the lower right side of the Piston.
I actually paid "LESS" for my CP Pistons than I did for the "Good Price" Noonan cut me. CP is not a new company, but they also have not been around as long at JE or JE's Owner Wiesco which is a company that I would never Buy another Piston from since my 2 stroke days. CP has not been into Bikes that long and the fact that they are asking for a Head means that they want to do it right.
Remember, when I had a problem with JE, I was laughed at and riddiculed all over the place for having the nerve to state that they could possibly make a defective piston. When I found a mistake that CP Made, they stopped everything and made me a new set in less than a week. Both companies mistakes were made in the Valve Pocket area but only one admitted to it and fixed it.
So yes, tell them how much more lift the cam you plan to use is going to have so that they can allow for it.
trenace
posted August 04, 2005 03:48 PM        Edited By: trenace on 4 Aug 2005 17:02
US Post Office will... I coughed up for the insurance!
Seriously, so far as I know CP is not only doing us right, but doing us very well indeed for what is mutually helping each other. My postage expenses are much more than being compensated for all around at the end of the day.
Sure, they could have gone out and sourced one... but why when within a few days of first contact, the customer offers to send a spare head? Probably fastest actually to just use my extra one.
And Mr Hill, yes, just specifying the extra lift is probably the best approach. I think Muzzy's does specify it.
Ra12r
posted August 07, 2005 06:05 PM
Spencer, you will be the first one talking about "your a distributer of CP", so order from you when they have a great piston for our bikes......!?!?! Be supportive of the folks thinking and trying new things and be supportive of the folks willing to share and help WITHOUT CRYING about money. I believe most people are not confortable with non-conformist thinking. Sometimes I feel like Galileo! The world is NOT flat!
gunner
posted August 07, 2005 06:25 PM
This mind set of helping is what makes the .org crew such a great bunch of guys. Allow me to explain that NO one is going to get rich doin this shit, so loosen up and share the info. Leave the Black majic to the guys in Vegas. Really guys cam timing and bearing clearances just aren't the kinds of things to hide. Simply put the more guys that do good in a sport = more guys entering a sport = MORE MONEY for everyone feeding from a given sport. Secrets are for grade school girls and closet fags. OH and for keeping from the IRS but that's another story all together. I mean no hard feeling or to step on any toes.
You never go wrong when you help a brother out!!!!!!! { In Short }
posted August 07, 2005 07:47 PM
Hey Vince, are your pistons, larger? or just stock pistons size?
Thanks....
ninja12
posted August 07, 2005 08:23 PM
i believe he when stock bore.
posted August 08, 2005 06:50 AM
Exactly Stock Bor, but that is all that is stock. .060 thicker Dome, Flat topped piston with a CR of about 10.5 to 1. I changed the distance from the top of the piston to the 1st ring (a compromise between heat and carbon) plus a few other things to keep sealing pressure.
posted August 08, 2005 09:16 AM
I have an extra stock motor, I am thinking about doing something with, but I want to go larger.... hell if I am going to blow something up on nitrous, I am going to make it go fast to start.....
Mad Mike
posted August 08, 2005 12:22 PM
Mad Mike
I had the opposite thinking. If I am going to go fast and use NOS, then why take the engine to the 9's and be on the ragged edge when all I need to do is change the jets? Easier to take an engine and make 150 HP and spray 150 than it is to make 200 HP and Spray 100 Shot! If either engine need more HP, a lot easier to change Jets to 175 than it is to make the engine have 225 HP
First I read everything I could and then decided to treat the engine like a Turbo engine. Make it as strong and understressed as possible and then Spray it for all it is worth. By not boring and stroking it, I am keeping the cylinders as strong as possible. It also helps the clamping surface to hold the head gasket. No additional stroke, more RPMS to work with and not have too much piston speed.
0.24209499359131 seconds processing time
