BIKELAND > FORUMS > ZX12R ZONE.com > Thread: GPS runs? NEW TOPIC NEW POLL POST REPLY
rc51eviltwin
posted July 20, 2005 08:03 PM
GPS runs?
well i finally got a decent run on my 12. WTF it only toped out at 175 MPH!is this about right for a stock 12?i was hoping a little closer to the 'BUSA 181 MPH since the 2000 model is not supposed to be restricted.any comments or advice will appreciated.oh the tac. was still dialing only 11,200 not quite red line but not much left.
Hells Dark Lord
living life, and loving it.
posted July 21, 2005 03:18 AM
my 12 would only turn 176 on a DYNO, it was down one tooth in the front.....Speedo would indicate more than 200 MPH at the time...
Megabyte
posted July 21, 2005 06:30 AM
My stock 2k 12 did 194 on the dyno. The speedo said 210
ridgeracer
posted July 21, 2005 07:31 AM        Edited By: ridgeracer on 21 Jul 2005 08:33
What were the conditions? Temperature? Altitude? You are not going to go as fast in the high desert at noon in the summer as you will on the coast at dawn. Also a 5 mph tailwind vs a 5 mph headwind can make a big difference.
You really need to tuck in at that speed. Knees, elbows. helmet. After you shift into sixth you don't need your left hand out on the handlebar anymore. Tuck it inside and hold on to the fork or triple clamp. Also removing your mirrors and turnsignals will make a difference. Remember drag increases by the square of your speed i.e. there is 9 times as much drag at 180 than at 60mph.
How many miles do you have on your bike? Maybe its just tired.
BTW I have a friend who swears his airplane goes faster after he waxes it and it only does 130
ridgeracer
posted July 21, 2005 07:34 AM
Oh, yeah I forgot the most important thing....
What color is it?
posted July 21, 2005 10:03 AM        Edited By: entropy on 21 Jul 2005 23:28
On my Y2000 12, 11200rpm indicated = 10700+/- real (measured w/a Fluke)
10700rpm real with 18/46 = approx 175mph (pn gps)
hmmmmmmmmmm
rc51eviltwin
posted July 21, 2005 08:46 PM
sunny just before sunset/95 degrees/2950' above sea level/about 8 MPH tail wind/funny you mention the wax 'cuz i waxed mine just before i left the house.drag was not a problem since it was still climbing but i let off since i could not see over an 1/8 mile anymore(not enough time to stop if i had to)oh yeah its a candy red 2000 model and the blinkers have been taken.what is the stock gearig for this bike?will the bike loose speed on the dyno because of the ram-air?what is HP supposed to read?oh and this bike has 24 freakin thousand miles so it might be a little tired LOL
2000 ZX12r>>sold
2001 RC51>>sold
1988 FLSTC>>sold
2004 ZX10>>sold
'07 GSXR 1000
"05 CBR 1000
'89 NSR 250
'05 metrakit
'03 SV 650
'01 FLTRI
'07 custom hardtail
redelk
Please... speak to the hand.
posted July 21, 2005 10:19 PM
That explains some of it. Drop down a few thousand feet (namely 3,000) and I think those top speed numbers might be "slightly" higher.
FastestBusaAround
I eat Fish...
posted July 21, 2005 10:46 PM
You meant 'Busa at 186MPH not 181 right? Because I know I have been on it at those speeds, according to my 2650 Garmin GPS...
FYYFF!!!
Hells Dark Lord
posted July 23, 2005 03:50 PM
my 12 was dropped one tooth in the front, and pulled all the way to the limiter....my 02 still had the limiter in it.....and I never corrected the speedo either.....it was plenty fast enough for me....lol
it pulled 181 hp on a DJ 250 in Jacksonville FL......
ridgeracer
posted July 23, 2005 04:19 PM
Using this air density calculator http://wahiduddin.net/calc/calc_hp_dp.htm with 95 F, 2950 ft. and guessing on the Altimeter Setting (29.95) and Dew Point (40) it comes up with a relative horsepower of 88% and a Dyno correction factor of 1.136.
In other words for every 100 horsepower you were making you would of been able to make 113 at sea level. You were just too hot and high
rc51eviltwin
posted July 24, 2005 07:47 PM
no i meant 181MPH i ride amongst three other '04 (stock) busas which i failed to mention and the best they can do is 181MPH.now theres is another with degreed cams and full exhaust that pulls 186MPH and another with 1510CC bore and all that other $$$ and it pulls a 205MPH.but for now i just want a base line before i start tweaking on it.
2000 ZX12r>>sold
2001 RC51>>sold
1988 FLSTC>>sold
2004 ZX10>>sold
'07 GSXR 1000
"05 CBR 1000
'89 NSR 250
'05 metrakit
'03 SV 650
'01 FLTRI
'07 custom hardtail
tuusinii
posted July 25, 2005 01:02 AM
You said it Yourself - You backed it up before You were at the top speed. It takes lot of road to get the last few MPH. And the altitude dosen't help either. All small things add up. When was it serviced, tire pressures, chain slac and lube, etc. And at 21k miles I wouldn't call it tired. Usually in the long term test in the magazines bikes make more HP after 50k km (32k miles) than they did after 5k km! And especially they usually have little better top end because things have loosened a little bit.
ridgeracer
posted July 25, 2005 01:08 PM        Edited By: ridgeracer on 25 Jul 2005 14:12
Sounds like this is what you really need.
http://maps.google.com/maps?q=lake+crescent+wa&ll=48.052382,-124.190483&spn=0.103559,0.238094&t=h&hl=en
5 miles of straight, level, unpopulated, seldom patrolled highway.
Its even a speedometer test zone so it has those big 1 mile, 2mile, etc signs posted along it.
rc51eviltwin
posted July 25, 2005 03:45 PM
well we got one of those,but ours is not so close to sea level!but ours is about 9 miles long matter of fact its known as "9 mile " 'round here.check it out it goes north where 1936 seems to stop http://maps.google.com/maps?q=lake+crescent+wa&ll=48.052382,-124.190483&spn=0.103559,0.238094&t=h&hl=en it also shows just how much oil bussiness we have around here.and no we dont get a break.we still pay $2.59 for premium unleaded.LOL
2000 ZX12r>>sold
2001 RC51>>sold
1988 FLSTC>>sold
2004 ZX10>>sold
'07 GSXR 1000
"05 CBR 1000
'89 NSR 250
'05 metrakit
'03 SV 650
'01 FLTRI
'07 custom hardtail
psycho1122
posted July 26, 2005 08:45 AM
Back in 2000, I tested my 12. I had Paul Dean from cycle world come out with their calibrated gun. My stock 12 with mirrors and all went 184 mph. Tach read 11,000 rpm and NO MORE! Tach error on my bike was found to be 700 rpm. So I was running at peak power (155) @ 10, 300. I had brand new BT010's on it at the time.
I did a second run on the 3 mile strech of road IN 5th GEAR! It went 179 mph and the tach STILL sat at 11,000 rpm and NO MORE! Never hit the rev. limiter.
Temp that a.m. was in the 70's and elevation was 1,100 ft.
I also don't feel that the "stock" ram air helped much due to all the leaks in the system. If it was all sealed up perfect I might have picked up 3-4 mph tops!
Now, the same bike with a pipe and map, one year later, fresh set of tires and everything else stock, I went 196 mph!
To this day, I still kick myself for not realizing that my ram air leaked so HORRIBLY!! I could have realized the full 8% benefit on top of the 173 h.p. that I had at the time. MAYBE I could have got 198-200.........Maybe.
your car is slow
Fuck Nitrous...Got Boost?
posted July 26, 2005 08:51 AM        Edited By: your car is slow on 26 Jul 2005 09:52
You are now exiting the internet...where all bikes eclipse 200mph with ease in stock form.
Real life is an eye opener eh?
Always easy to tell apart those that have actually done it....rather than talked about what they read somewhere...or what it "should" do.
That said....I have no doubt you could get more MPH out of it with little or no work to the bike itself.
Riding up top takes alot more skill and concentration than one would imagine...which is also why its safe to say that "anyone can just twist the throttle and go 200".....has never even come close.
Do not taunt happy fun ball!
fastestbusaaround
I eat Fish...
posted July 26, 2005 09:02 AM
My 04 'Busa just has:
Airbox mod
K&N
Yoshi RS3 Race
PCIII
Dyno's at 168.5 HP and 103 TQ
It did 186 more than a few times (Garmin GPS Speed)....I weigh about 210, so its strange that the other machines don't hit that 186 mark! Even my 10R hits 186...and thats bone stock. Maybe tire pressure to low or biggger than stock windsheld?
FYYFF!!!
0.23652410507202 seconds processing time
