BIKELAND > FORUMS > ZX12R ZONE.com > Thread: problem resolved (thanks i needed that) NEW TOPIC NEW POLL POST REPLY
posted June 14, 2005 12:50 PM        Edited By: VincentHill on 22 Jun 2005 17:09
Problem Resolved (Thanks I needed that)
I Had planed to finsih up my bike this Sunday when it is cooler and then go to Virginia to get some Dyno Tuning. T then called Bergie's Least favorite person only to find that the Building has been sold and they have to move and the new place has no room for the DYNO!
So now, I have to go to Cockeysville and pay a lot more money than planned at a Time I had not planned also. They do good work, but just more junk to deal with! I hate to need to convince people to set my bike up at 12.8 as opposed to 13.2 (Just things like that!)
See last post by me
wilson1
posted June 14, 2005 03:33 PM
what does 12.8 and 13.2 refer to ?
osti33
posted June 14, 2005 03:39 PM
Air / Fuel ratio.
wilson1
posted June 14, 2005 03:41 PM
thanx i wasnt sure what it was
Rac4It
Bergie
posted June 15, 2005 03:23 AM
HAhahahaaha that's great! No, not what happened to you VH, but you know what I mean Finally some retribution!
posted June 15, 2005 07:07 AM
You are a Bad Man Bergie!! Neat to meet your Dad also! (The Only Dad I saw there except for me being Angie's Dad #2
Rac4IT
Bergie
posted June 15, 2005 11:30 AM        Edited By: Rac4IT on 15 Jun 2005 12:31
I hope champion goes under and the illegal aliens that work there get deported back to the UK!
spencercyclecom
posted June 15, 2005 11:33 AM        Edited By: spencercyclecom on 15 Jun 2005 12:33
if you are spraying alot of Nitrous...Vincent...You had better set it up alot richer than that when on the spray....... 12.8 will go way lean when on spray...say around 100hp or more
I would say 11.7 on the spray..... 150 shot...will be plenty safe and live awhile...
just my 2 cents
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
posted June 15, 2005 12:15 PM
just my 2 cents
Thanks Dr. Doug, yours is worth a lot more than .02 or even .25
Actually I have a wet system with a bypass fuel regulator and the problem is actually going rich because the bottle pressure starts to drop and the fuel stays the same.
spencercyclecom
posted June 15, 2005 04:54 PM
run a piggy back bottle to aid in keeping up the bottle pressure during the maxton run...such as a 1lb bottle or even better a 2lb bottle. Thats why most Promod bikes run the 5lb bottles.....in dragracing
Doug Ray
SpencerCycle.com
Fax 1-704-642-0987
posted June 16, 2005 04:28 AM
The 5 pound Bottle "IS" What I am Up to Next! Just hard to stay ahead of some people I also have a heater that I use prior to the run to get the pressure up to 1,000 so that I am slightly lean to begin with and slightly rich at the end of the run where it is working the hardest.
rac4it
Bergie
posted June 17, 2005 09:52 AM
VH are you still planning on Maxton next weekend?
posted June 17, 2005 10:49 AM
YES! I tried to call you but you phone may have know who I was and rejected the call I got your call but no # to call back. You have e-mail and a PM>
rac4it
Bergie
posted June 19, 2005 05:44 PM
I believe you have an old phone number for me. I've long since moved to GA and my new cell number is 678-371-9148.
posted June 22, 2005 04:16 PM
I just spent "ALL" Day on the Dyno. For some strange reason, every Cell was very lean and as Both DOugs Know, it takes a while to remap from "ZERO"!
I was surprised because I felt that the Muzzy pump would have made it richer but maybe my Bypass Regulator and mod made it leaner.
The Bypass did what it was supposed to "NO LEAN Spikes period" Still not dialed in perfect but I have about 270 Clean HP and know how to get about 20 to 30 more and not even be close to trouble. The EGT was in the mid to high 1,200 degrees and only the last run did it hit 1,300 so I have a little more to go before I hit 1,350 degrees which is (As far as i know) still in the safe zone)
Apology to Doug Ray because I saw what he saw but on another bike. "7" Hp more by being lean at 14 to 1 as opposed to 13.5 or 13.1 to 1. I had to see this for myself but I saw it on my own bike!
osti33
posted June 22, 2005 05:15 PM
Glad you got it worked out Mr. Hill.
ninja12
posted June 22, 2005 09:18 PM
Will those 7 hp tranfer to mph on the track?
rac4it
Bergie
posted June 23, 2005 04:11 AM
I think the point is you're better off safe (13.1-5:1) vs lean and gaining +7hp
posted June 23, 2005 04:56 AM
AMEN Bergie
I rather have 160 HP that I can duplicate over and over and hit the Bottle for 280 to 310 HP than have 167 HP and over the edge. I gave up 20 HP to gain 100 (150 vs the 50 Shot). Remember Old people are a lot more conservative than the young who will build and engine to the edge 210 HP and then Spray 100 more
rac4it
Bergie
posted June 23, 2005 06:09 AM
True. Good way of comparing 310 HP in two different methods of getting there.
0.2528018951416 seconds processing time
