BIKELAND > FORUMS > ZX12R ZONE.com > Thread: wheel fitment NEW TOPIC NEW POLL POST REPLY
jus1975
posted June 11, 2005 10:56 PM
wheel fitment
Do you guys know if an 18 inch wheel would fit the front of my 12.
frEEk
posted June 11, 2005 11:14 PM
depends on the size of the tire u mount on it for one. if the outside diameter is bigger, u'd have to move the fender (obviously) and check if there is still clearance between the tire and rad when the forks are fully compressed. of course u'd need to make sure the axle fits right first of all. also, an 18" wheel would likely slow handling (racers sometimes go to 16.5)
posted June 11, 2005 11:49 PM
Why?
jus1975
posted June 14, 2005 12:15 PM
I going with a 300mm rear that 18inches and it would look better with an 18in front. I guess I will have to try it a see. I have seen a Busa with the same set up and it made a nice difference.
gunner
posted June 14, 2005 06:50 PM
That's just not right. No Sir not right at all
Hells Dark Lord
living life, and loving it.
posted June 14, 2005 07:03 PM
say it aint so......
NINJA12
posted June 15, 2005 07:10 AM
Come on guys,
Let hims dress it up.
Some are into the LOOK of things,
some are into the Performance.
IF he wants to make it look better to him, let's
cheer him on. After all some of you bought
the wrong color (red) but i still love you.
After all the zx12 is one of the most flexible bike ever.
Jus1975 be sure to post us some pictures, OK?
zxfingyz
posted June 15, 2005 08:03 AM
Can you post a picture of that busa or any bike with that size tire on it?
What other changes do you have to make to accomodate that size tire?
ninja12
posted June 16, 2005 12:43 AM
custom swingarm and aftermarket wheels to start.
trenace
posted June 19, 2005 06:01 PM        Edited By: trenace on 20 Jun 2005 15:59
Clearance with regard to bottoming out can't be too big an issue, since what matters there is the radius, which is changing only half an inch from the wheel (maybe a little more from the tire.)
And dropping the front at the triple trees by half an inch, equivalent thing really, is not that major.
Compared to the change of going to a 300 rear the handling differences from changing the front diameter a little would have to be way less. Maybe even an improvement from being more balanced out, but I don't know.
No matter what the handling will be killed, though still probably not as bad as the more extreme choppers. No one seems to have ever reported "even" a 250 as being good-handling. 300 would have to be for show or you-know-the-handling-is-terrible-and-you-account-for-it, very moderate riding. After all you can drive a big truck and it does not handle well either but can it be driven? -- absolutely when you account for it.
Another possible idea -- maybe it would be better (for your purpose) to use a wider front wheel and tire, but still 17 inches?
Probably depends mostly on what tire you want, whether you go 17" or 18".
0.27421188354492 seconds processing time
