BIKELAND > FORUMS > ZX12R ZONE.com > Thread: The Clutch NEW TOPIC NEW POLL POST REPLY
Marv
posted May 31, 2005 05:48 AM
The Clutch
Another clutch question,
While riding in 4th gear rev's between 8k & 10k rpms I feel a slight slippage in the clutch. Does this mean its time to replace or can an adjustment be done?
posted May 31, 2005 06:14 AM
It's toast. Sorry.
NINJA12
posted May 31, 2005 06:16 AM
any slack in the clutch cable?
IF not you may be able to adjust and buy some time.
Ususlly once they start slipping it's not long before
they are completely gone.
Some people will ride until the bike stops pulling
I don't recommend that, because all that clutch material
is in your oil working to kill your bearings.
osti33
posted May 31, 2005 01:59 PM
When it starts to slip it is time to buy a new one. Sorry.
posted May 31, 2005 02:41 PM
If you havent aligned the last fiber....then yes...there is still some life in it.
marv
posted May 31, 2005 08:58 PM
Damm, Damm, Damm!!!!!!
posted June 01, 2005 06:44 AM
It's toast. Sorry.
1-800-buy-a-muzzys-clutch
marv
posted June 03, 2005 08:51 PM
I have an 03 and this is the 2nd clutch to go bad on me?? anyone else having clutch issues?
posted June 04, 2005 05:39 AM
Thats the way it is...Just buy OEM Kawasaki clutches, 12 -1131 friction plates and 11 - 1123 steel plates all 1.6...Thats all you need!!!
posted June 04, 2005 06:09 AM
If you continue to have clutch problems AFTER you have installed 6 HD springs from Brock, Schnitz, or who ever... you will need a lockup clutch or better gearing.
The 3 Muzzy springs work ok, but in reality you need 6 springs! Its all about static spring pressure.
2.0 steels help too.
Ive had OEM packs last 10,000 miles of HARD abuse. Remove all those mini springs and fibers too. Only use FULL sized plates and fibers.
matt sterbator
Hiding in the bushes
posted June 04, 2005 07:51 AM
Clutches are consumables on these bikes... kinda like tires and changing oil... lubing the chain, lol
zrexpilot
posted June 09, 2005 08:05 PM
I need to do my clutch also. Why do you recommend 12 -1131 fibers and not the 1143 fibers ? They look like different material.
Do I chunk those spacers also ? The 2 sets of 2 rings.
ninja12
posted June 11, 2005 05:36 AM
muzzy clutch kit is a deal when you it's time to replace.
stock is ~$200.
The muzzy kit is ~$300, which includes
a drilled bearing , drilled hub, 3 heavy springs, set of steels and fibers.
It works.
h0micide
posted June 11, 2005 09:50 AM
I have the muzzy kit in mine.The original clutch basket exsploded,and i do meen exsploded.
most of the fibbers and steels where ok though.and thay look and fill idenical to the muzzy ones.I just burn my cluch up yesterday.so bad 1st gear was like nuteral.So i took and orijenal steels and sanded the burnt ones and did a lil mix match.The fist fiber the one with the big i.d. i left out and started with a steel instead.works. So far so good.
ninja12
posted June 11, 2005 07:31 PM
I don't think you should start with a steel.
Start with a fiber, end with a fiber, you can put two steels
together somewhere in the moddle.
my .02
NOX
PMRA / TMRC Super Street 4022
posted June 21, 2005 03:51 PM
never start or end with a steel, and dont stack steels unless you want to make it slip. the only people that do that are those with lock ups that want to make the clutch slip, but still have the ability to lock the clutch down track.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
matt sterbator
posted June 21, 2005 03:56 PM
Ummm, how is the clutch going to slip if you stack steels ?
NOX
posted June 21, 2005 04:03 PM        Edited By: NOX on 21 Jun 2005 17:05
less friction, the friction comes from the fibers and steels contacting, stacking steels is an old dragracing trick to get the clutch to slip out of the hole while using a lock up.
I have done it with this bike, my Pro ET ZX12
http://www.catalystracingcomposites.com/catalyst_racing_composites_011.htm
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
matt sterbator
posted June 21, 2005 04:12 PM
All you do with stacking steels, is essentially create one thick steel. The steels don't have any friction between them since they're all on the hub and the fibers are on the basket.
Unless there's something I'm missing here.
NOX
posted June 21, 2005 07:50 PM
It takes away clutch surface..................
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
matt sterbator
posted June 22, 2005 07:51 PM
I still don't see how this works, unless you're running less fibers or something.
vozizm
Got Nothing Witty To Say
posted June 22, 2005 08:51 PM
VOZ
ninja12
posted June 22, 2005 09:08 PM
he is right!
BUT the muzzy clutch has already reduced the clutch surface area by ~8 percent,
If you are running a muzzy setup and you stack steels you only increase stack height.
If you were running stock setup and you add another steel you will probably have stack height too tall.
eastbaydave
posted July 14, 2005 09:13 AM
I had mine apart 5-6 times in the last year. I just can't get it to stop dragging/making it hard to shift at times (especially into 1st from a stop- ker-crunch! = loud!) It seems to be stack related? 11 frictions & 10 steels, & I keep trying changing sizes of the steels/varying the stack height- yet can't seem to find the "sweet spot."
Even tried (current install) back to back steels per somes suggestions, yet still I have the same problem. It FEELS like it is dragging very slightly, causing this poor shifting. Bike only has about 8K miles on it so I don't think it's gear dogs or shift fork related. .
I really don't do many burnouts/wheelies to speak of (a few, but not that often- most wheelies are power wheelies), & only been ot the drags once (4 runs/1 night) several years ago. It has the Muzzy clutch kit & billet basket installed. I would be at the drags if I could figure this out...
I'm really tiring of pulling the body work, clutch/cover/gasket trying to find the problem. It's getting really really old- especially on a low-mile machine. One of the numerous reasons I don't ride it much...
Any suggestions?
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
your car is slow
Fuck Nitrous...Got Boost?
posted July 14, 2005 09:46 AM        Edited By: your car is slow on 14 Jul 2005 10:47
I think he is saying that if you at one time have 11 steels and 12 fibers....but stack a steel....you now have 12 steels and 12 fibers....you still have exactly the same friction area you once did. Still 24 fiber faces touching 22 steel faces (and the basket/pressure plate for the last two).
Im not a physics major or anything...but the pressure plate pushing on a steel/steel combo would indeed produce a pretty good amount of friction. There is far more surface to surface tension between two identical pieces of metal under high pressure...than the raised "ribs" of the friction plate
And if you are tired of pulling plastics....cut yours so you can take off the clutch cover without removal of the plastics.
Do not taunt happy fun ball!
0.29126405715942 seconds processing time
