BA
posted May 14, 2005 09:32 AM
Edited By: BA on 14 May 2005 10:59
Engine Building question: Checking cam timing
I wasn't sure whether to hit the Dragbike forum or here, but, hopefully the right people will see this.
Well, my engine is getting "re-rebuilt" now by someone who knows what they are doing. (unlike last time....Thanks EPC... )
The guy is traditionally a Suzuki and Busa guy though. We're wondering how people set up their pointers on the bucket for the 12R. I'd love to hear from you guys how you set yours up and which cylinder you used.
PICTURES WOULD BE AWESOME!
I guess on a Hayabusa, it's easier to get perpendicular to the lifter, and not come at it from an angle like it seems we have to on the 12R.. The theory being that coming from an angle will skew your actual reading slightly.
Oh and while I'm at it, what kind of COLD, 0 miles cranking-compression should I expect?? I've seen others say 225psi or so for a 1270, but, I'm not sure if that was with rings seated and a few hundred miles or not. PS. Mine is a 1290.
The last builder had me a whopping 125psi.
Doug, JC, Kadby, MM, Berg, and any other smarties I'm leaving out, I need to know how you do it!
BA
posted May 14, 2005 04:59 PM
By the way, I just found out that a stock sized head gasket was used when the1290 was assembled the first time.
Is there a special over-bore gasket that I should have in there? Where should I get a new one and is there a brand to look for? (cometic?)
Ra12r
posted May 14, 2005 07:25 PM
You do need a bored gasket too. Basically a stock gasket cut bigger. I believe that Bob Carpenter should have some as he sells a 1290 kit.
I use #1 to measure the cams. Just easy for me to get to. Yes, i hate that I am not able to get perpendicular, but I try to get as close as possible.
What are you going to set your cams too?
ZXLNT
posted May 15, 2005 06:22 AM
BA
posted May 15, 2005 07:39 AM
Thanks Ra, Thanks Z.....
Good pics, it looks like you're using #1 too.
Ra, I was planning on using a 103I/105E timing unless I get schooled differently.....
Y2KZX12R
CompetitionCNC.com
posted May 15, 2005 01:56 PM
Hey BA, I made a chart several years ago to correct for just what you are talking about.
all lift corrections are @.040"
10 deg from perpendicular = +.006"
20 deg from perpendicular =+.0026" also = 1deg of cam timing
30 deg from perpendicular =+.0062" also = 2 deg cam timing
40" deg from perpendicular =+.0122
50" deg from perpendicular =+.0222
I use a very small 90 degree hardened allen wrench mated to an adaptor. It allows almost zero angle deflection.
Just make sure the contact point never moves off the end of the 90 on the allen wrench.
Y2KZX12R
CompetitionCNC.com
your car is slow
Fuck Nitrous...Got Boost?
posted May 15, 2005 02:19 PM
didnt madmike sell a kit that had all the items necessary to do this? Its been awahile..so I may be way off.
Do not taunt happy fun ball!
osti33
posted May 15, 2005 03:40 PM
Edited By: osti33 on 15 May 2005 16:41
quote: didnt madmike sell a kit that had all the items necessary to do this? Its been awahile..so I may be way off.
Yep. He sells the whole kit(nice too, I have one). A good kit and a good price.
posted May 15, 2005 09:03 PM
What they all said. You need to make a litle "foot" to catch the edge of the bucket.
Remember, it doesn't need to folow the bucket all the way down. It can stop on the edge of the tappet bore. You only need to measure the top 2mm of travel to get lobe centers.
Doug
kcadby
posted May 16, 2005 12:56 PM
Got yer PM...
ditto what DOUG says also...although I do get my guage to read the full lift
posted May 16, 2005 01:22 PM
Yep I have the kit, it has everything in a wooden case, nice kit. and I use doug's Instructions he posted! helped me a bunch. still a pain in the butt!
MM
BA
posted May 16, 2005 01:41 PM
Thanks to all of you for the info. That is great info and Jim, I'll be saving that info to a file as well!!
Anyone have thoughts about what cranking compression I should expect with a 1290? A ballpark number is fine, I was going to guess 200-215 area before it's put on the road.
