wekoli
posted May 05, 2005 09:52 PM
2000 ZX12R Oil Leak!!!
I noticed after riding my bike to work today, Yeah, I was riding hard, bouncing of the limiter After the bike was sitting in the parking lot. I noticed the bike was leaking on the left side of the bike. If you look on the left side of the bike, there is a black tube with some type of filter looking thing. If you follow the tube up, it leaking from above that. I stopped by a shop today and the guy said it looks like oil is coming from the airbox. I asked him how can oil get up there, He said either I had too much oil in the motor, or I have a cracked piston.. As for the bike, It runs great. Like a bat out of hell. I checked the oil lever through the site glass, and the oil is right in the middle.. So what's going on with my bike?? And suggestions?? Aloha, Victor BTW, I had by bikie worked on at the end of 2004, Valve Adjustments, and oil change. Nothing has been done to the bike since.
posted May 06, 2005 06:53 AM
That's normal.. that's and overflow bottle for the crankcase vent (if I'm not mistaken) ... you need to empty it out e ery now and then.. if you've had your bike since 00 and never cleaned it out, then good chance it's full after 5 years of riding.
wekoli
posted May 06, 2005 10:21 AM
YES SIR. I found my service manual. And yes, the bottle and line was full. Now I'm kinda thinking that those guys at the motorcycle shop don't know WFT there talking about. Thanks for the response. Aloha, Victor
posted May 07, 2005 06:52 AM
No say it isnt so an actual Dealer that does not know what they are talking about????
wekoli
posted May 07, 2005 10:10 AM
Aloha MadMike, I didn't go to the Motorcycle Dealer. It was just a motorcycle Repair Shop. I don't think I'll go there for any repairs. There was a ZX10R that had the same thing. Oil in the are box, They said it had a cracked piston.
beansbaxter
posted May 07, 2005 10:57 AM
I have a 2002 and I have never cleaned this out, so what exactly do I need to clean out? My airbox????
Ra12r
posted May 08, 2005 07:36 AM
I believe you are getting the oil through the clean air system. You should NOT be getting the oil as blow buy up through your injection system. If so then you need a engine rebuild.
zxfingyz
posted May 09, 2005 07:26 AM
While you are looking in the airbox why not remove the sand too?
Yep, sand.
NORTY
posted May 25, 2005 12:12 PM
The sand in the airbox is casting silica. You'd think "K" would have removed it from the frames after they are welded-but nnnnnnoooooooooooo! At least the frames don't break like the GSXR 1000 ones do after hitting a wall at "triple digit" speeds...
A NOD IS AS GOOD AS A WINK TO A BLIND HORSE
