BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12 crankshaft balancer NEW TOPIC NEW POLL POST REPLY
anesthesiac12
posted May 05, 2005 09:32 AM
I am freshening my engine again, and have in the past heard rumor of removing the crankshaft balancer. Has anyone done this and what advise do you have to prvent tedious troubleshooting....
posted May 05, 2005 12:12 PM
buy the Muzzy plug. cost 20 bucks. and take it out.... I have only done it with the cases split but I believe you can do it in the motor? correct me if I am wrong anyone!
MM
osti33
posted May 05, 2005 01:29 PM
I think you have to split the cases...It's been a while since I've been in there. I'm at work right now and don't have the manual in front of me.
kawachan
posted May 05, 2005 10:28 PM
You have to split the cases.......
RED NINJAS RULE!!
NINJA12
posted May 06, 2005 09:20 AM
never say never but ....
I couldn't get it out without splitting the cases.
Marcos Peguero
posted May 06, 2005 12:39 PM
No, old topic.
  Ignore this member    Click here to visit Marcos Peguero's homepage.
posted May 07, 2005 06:50 AM
Good that answers that, but you can leave the entire top end intact, and just split the cases and pull it out. button up the cases again and away you go!
MM
aliveagain
posted May 07, 2005 11:42 AM
The shaft will be able to be pulled straight out,I'm not sure the counterbalance will drop straight down.With my cases empty it looks like you could slide it in back of the oil rail to come out,however without the rods and crank in place,I can't say for sure.You didn't say if your crank was balanced or not,Idon't even know if that matters.
Ra12r
posted May 08, 2005 07:31 AM
The diameter is too large to drop down and out. You MUST split the cases!
ninja12
posted May 08, 2005 06:29 PM
told ya
kcadby
posted May 11, 2005 03:57 PM
I would want to "ballance" the pistons, rods, crank...at the same time anyway...
0.41175985336304 seconds processing time
