BIKELAND > FORUMS > ZX12R ZONE.com > Thread: redelk 636 master cylinder on zx12r NEW TOPIC NEW POLL POST REPLY
ZXLNT
posted April 23, 2005 12:38 AM        Edited By: ZXLNT on 27 Apr 2005 00:20
RedElk 636 Master Cylinder on ZX12R
Sherman I know you put a ZX7R master cylinder on your old 12R. How did you mount the resivoir cup to the triple clamp? Or did yours have a bracket right off the master cylinder? The 636 does't have the mounting point on the master cylinder....
Thanks...
litozx12
posted April 23, 2005 02:21 AM
For what is that.... i dont understand
Marcos Peguero
posted April 23, 2005 04:22 PM
I have a gsxr750 2004 master cilinder in the zx12r, I did have to make the cup holder braket.
Nice.
  Ignore this member    Click here to visit Marcos Peguero's homepage.
ZXLNT
posted April 23, 2005 04:27 PM
Did you just drill and tap a hole on the upper triple clamp???
Marcos Peguero
posted April 23, 2005 04:31 PM
No man, I took a little piece of metal and atached one end with the bolt that holds the master c. and the other to the cup.
redelk
Please... speak to the hand.
posted April 26, 2005 10:01 PM        Edited By: redelk on 26 Apr 2005 23:14
ZXLNT, I used a universal Nissin master cylinder (LP # 400-27351) that had the reservoir bracket mounting to the "mirror mount" on the brake lever bracket.
-Ernest Hemingway
zxlnt
posted May 06, 2005 01:54 AM
I got it mounted the other night. Couple things I had to do were grind off the protrusion next to the banjo bolt hole that keeps the brake lines from moving around. Also had to turn the eyelets on the brake lines about a half turn so they fit flush against the master cylinder. Other than that it was a no brainer. Some new brake fluid and a little bit of time spent bleeding them and it was done. Works great and looks good..
Marcos Peguero
posted May 06, 2005 02:31 AM
How much did you get it?
ZXLNT
posted May 06, 2005 03:31 AM
I paid 50 dollars for it.
Marcos Peguero
posted May 06, 2005 10:05 AM
Nice, very nice price....
call me if you find another one and dont whant it....
ZXLNT
posted May 06, 2005 10:07 AM
Master cylinder off a ZX7R or ZX9R will work. A Suzuki GSXR will also. Most of them are all Nissin's anyway. Not really that hard to find. At least here they arent
Marcos Peguero
posted May 06, 2005 11:34 AM
Yes but I mean a radial 19mm nissin pump.
I you put a 16mm then you put almost the same pum as stock.
ZXLNT
posted May 06, 2005 12:59 PM
I just wanted the looks more than anything. The 636 master cylinder works great for me..
Marcos Peguero
posted May 06, 2005 02:22 PM
The 636 master cilynder is a radial one???
0.25170016288757 seconds processing time
