BIKELAND > FORUMS > ZX12R ZONE.com > Thread: v. hill - exhaust install questions...the arata is here! NEW TOPIC NEW POLL POST REPLY
wristrocket
posted April 04, 2005 09:45 PM        Edited By: wristrocket on 6 Apr 2005 00:23
V. Hill - Exhaust install questions...the ARATA is HERE!
1. The exhaust gaskets...there is a smooth side and a seam side. Which way faces the exhaust port? The totally smooth side or the side with the seam?
2. What is the torque specs on the flange nuts?
3. Do I need to apply anything to the pipes at the joints?
4.Any tips/suggestions?
Thanks for your help.
Test fitting pic....
wristrocket
posted April 05, 2005 11:23 PM
46 views and no one knows. Please tell me you all dont ride stock bikes! Sheesh..either you guys dont know shiet or your all stingy with da info. Howz about a little love for a fellow 12 brother. WR
ninja12
posted April 05, 2005 11:54 PM
i'll try .
1. Don't mater on the gaskets
2. also not critical
3. no
4. this info is from the way i did my akrap 1 year ago not a problem yet.
zx12boricua
posted April 06, 2005 05:19 AM        Edited By: zx12boricua on 6 Apr 2005 11:26
Since you are already there, remove the Kleen air valve, muzzy fan, do the crankcase mod, put some water wetter and you should be set for now.
2012 ZX14R Blue Current
2007 ZX14 Black Sold
2006 ZX10R Yellow Sold
2002 ZX7R Silver,Black,Yellow Stolen
2000 ZX12R Red Sold
1989 GPZ900R Red Sold
posted April 06, 2005 07:31 AM
I mount the Gaskets with the Ridge side facing out (My thinking is that the I do not want the seam facing the exhaust gas flow but I do not think it makes that much difference)
To ease ever taking them apart I use Hi Temp Copper RTV sealer. Titainium seems to want to weld itself together. By putting this in the seams, it seems to help getting them apart if the need ever arises!
I also put a dab of Antiseize on the studs that mount the Spigots. Torque?? Not a lot, maybe 100 inch pounds!
I do remove the radiator and install the Muzzy fan blades because the thinner pipes allow more heat to melt the plastic fans!
wristrocket
posted April 06, 2005 11:08 AM
Thanks guys I appreciate the help very much. All has been done and she has fired up and sounds SWEET! PC map has her idiling like a kitten....twist o'da wrist and she snarls like a LION. Cant wait for a ride this weekend. WR
0.23081684112549 seconds processing time
