BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Attn: Doug Meyer - 2002 throttle cam NEW TOPIC NEW POLL POST REPLY
Zx23rr
Mahogany Bomber Pilot
posted October 20, 2001 03:19 PM
The most exciting improvement that I can see on the 2002 is the oval throttle cam! Hopefully someone will copy it and put into production for 2000-01's!
- Doug Meyer / Muzzy comes to mind! Put me down for the first one!!! zx23rr@home.com
Doug, is this do-able? Frank
Later............................./
posted October 20, 2001 05:34 PM
"progressive" throttle
We're lookin' at it.
Doug
magzx12r
posted October 22, 2001 10:25 AM
Will the 2002 throttle not fit/work on the 2000-2001?
Mark
'03 ZX-12R
'12 1199S
posted October 22, 2001 10:31 AM
Don't know yet. We haven't actually seen a 2002.
Otis
Captain Kickstand
posted October 22, 2001 10:43 AM
and the benefits of this would be?
It's a free country brother
Wildman
I only look confused
posted October 22, 2001 11:07 AM
The benefit would be easier to control throttle at low settings for less lurch off idle without going to a half turn throttle.
If you build something Idiot Proof, The world will build a better Idiot.
posted October 22, 2001 12:32 PM
You know that part when you're making a tight 90 deg turn in one lane like into a driveway and you give it "just a little" throttle and you then go wide and almost hit the bushes and so you back off and lurch like an idiot and then pull in the clutch?
It would fix that.
Doug
posted October 23, 2001 01:07 AM
... lurch like an idiot...
pretty accurate description of my 60' "technique"...
FuckMeRunnin
posted October 23, 2001 09:40 AM
Sounds like a improvement I would want.
"What happens if you get scared 1/2 to death twice?"
posted October 24, 2001 04:08 AM
Yah, should be fairly cheap, too!
posted October 24, 2001 05:36 AM
Guys...In slow riding you modulate your speed with the clutch and brake while keeping the throttle steady at lets say 2000rpm ( can be any RPM )
So,in this situation the throttle cam would not be needed!!!
As for riding around in traffic and normal riding than it's a big help!!!
12RPilot
posted October 24, 2001 05:56 AM
I must be a lousy rider then....I lurch this bitch quite often.
NESBA #209
pat830
posted October 24, 2001 06:38 AM
I've done that.
Lurched like an idiot a few times myself.
"You Rang" in my best Lurch voice.
Bikelover
posted October 24, 2001 05:51 PM
Hopefully it would make 1st gear wheelies a little easier to control as well.
posted October 24, 2001 07:01 PM
Crotch,
Regarding your post. Very appropriate tag.
Wildman
posted October 24, 2001 07:14 PM
It's not really for slow riding.
You've all heard (I hope) Slow, Look, Lean, Roll?
Well, between lean and roll it helps to not have the bike lurch when you roll on the throttle.
That's what it's about.
posted October 25, 2001 06:59 AM
Thanks Doug...
Hey...I'm not very smart but I can lift heavy things!!!
Yes, I do know that the throttle cam would be a great help...So,hurry up and start banging those puppies out!!!
BallisticZX12R
& Deals Gap Board Member
posted October 25, 2001 07:13 AM
Doug
Doug's,
Line might be one of the best I have seen in years.
Bart
Be fast and Be safe
  Ignore this member    Click here to visit BallisticZX12R's homepage.
princesskiwi
MISTRESS of SMACK
posted October 25, 2001 07:37 PM        Edited By: princesskiwi on 25 Oct 2001 20:38
It would fix that.
Doug
Hey, how did you know I do that every time?
LOL
RidgeRacer
posted October 26, 2001 07:55 AM
Actually I was hoping it would shorten the last 25% of throttle instead of lengthen the first 25%. As it is now I have to either 'preload' my wrist or drop my right elbow to get it all the way open.
When your just cruising around and the guy next to you drops the hammer you don't want to close the throttle for second just so you can reposition your hand so you can get on it all the way.
posted October 26, 2001 08:39 AM
That's actually what it DOES do. The movement required for a given throttle opening becomes less and less as you open the throttle. The pulley is elliptical.
Doug
ZXtra
posted October 27, 2001 06:43 PM
Does anybody know if it will cure the lurch when you get back on the throttle in the middle of a corner? -ZXtra
posted October 28, 2001 01:18 PM
No- that's a mapping thing (assuming you have a pipe). But it will be easier to deal with.
ZXtra
posted October 28, 2001 11:14 PM
Thanks Doug! -ZXtra
psycho1122
posted October 29, 2001 07:23 PM
If muzzy produces a cam to replace the existing unit on the 2000 I would buy it in a heartbeat!!!
0.33842182159424 seconds processing time
