BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Dial indicator for checking Rotors NEW TOPIC NEW POLL POST REPLY
eric00zx12r
posted February 12, 2002 04:22 PM
anyone know where I can find a dial indicator to test the trueness of my front rotors (See if they are warped)?
None of the so called parts places around here has anything even close to useable.
Eric
00ZX-12R
Candy Persimmon Red
eric00zx12r
posted February 12, 2002 05:03 PM        Edited By: eric00zx12r on 12 Feb 2002 17:04
I found this, wonder if it would work
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=1717
Eric
00ZX-12R
Candy Persimmon Red
kcadby
posted February 12, 2002 06:29 PM
That guage only has .030" travel...
That SERIOUSLY limits what you can use this guage for...
You would be much better off gettting a regular dial guage that has more travel (an INCH)...it can be used for many other things like...cam degreeing...
You can SEE your disc run-out by simply holding or clamping, tapeing something onto your front end that 'almost touches' the rotor...turn the wheel and watch the gap...
A guage will obviosly give you numbers but...the visual will let you see an obvious problem before you get the guage...
TedG
posted February 12, 2002 06:57 PM        Edited By: TedG on 12 Feb 2002 18:59
Harbor frieght has a regular dial indicator that will work fine.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=623
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
redelk
Please... speak to the hand.
posted February 12, 2002 07:59 PM
I just got a "basic" one
Got one from AutoZone. It will measure up to 2" in increments of .001". I bought a "L" bracket that was at least an 1/8" thick at Home Depot. I think I have less then $30 in the whole "set up". It was VERY accurate and I learned quite a bit about rotor warp. Of course, I also learned of the disadvantages of drilling "L" brackets without eye protection too. That lesson involved a trip to a "doc-in-a-box" emergency room and later, an eye specialist... to get the metal out of my eye!
E-mail me at adcraft@cei.net and I send you some pictures of how I mounted it to the fork tubes. Hell, if you want, I'll send you my whole "report" on brake rotor warpage and some possible ways to actually reduce a slight warp in your rotors. I thought it was still here, but I couldn't find it after doing a quick search.
-Ernest Hemingway
0.24023199081421 seconds processing time
