BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2002 crank in a 00-01 motor? NEW TOPIC NEW POLL POST REPLY
posted February 17, 2005 04:31 PM
Anyone do this? Can it be done?
Five 0
posted February 17, 2005 04:37 PM
Dont know why not. I have a 2000 in my 2003!!!
5-0
osti33
posted February 17, 2005 04:51 PM        Edited By: osti33 on 17 Feb 2005 16:56
5-0 is right on the money. It will work fine.
posted February 17, 2005 09:02 PM
Guys tell me what you had to do to get a 2000 motor to run perfect in a 2002/03/04 frame???
Thanks!!!
osti33
posted February 17, 2005 09:55 PM
Thanks!!!
I was talking about just the crank. Not the whole motor.
You would have to change the motor mounts at the very least. 00-01 are different from 02-04. Not sure what else would need to be changed.
posted February 18, 2005 05:29 AM
it has to do with the head and cam-timing sensors. if you change those out, you should be fine. swap heads=motor mounts and sensor changed. I believe that will work.
johnnycheese
posted February 18, 2005 05:30 AM
the gear is wider on a 02 and up for the starter drive,I think
posted February 18, 2005 04:39 PM
It's easy to go the other way, 'cause you can drill and tap the B model head to accept the A engine mount, but the A doesn't have the bosses for the B mounts. You'd need an A head to fit an A frame. Once you had that you could use the B cams and the B ECU without the cam sensor- I think. :-)
Doug
0.31993699073792 seconds processing time
