BIKELAND > FORUMS > ZX12R ZONE.com > Thread: haed gasket problem?? NEW TOPIC NEW POLL POST REPLY
phantom
posted January 14, 2005 06:36 PM
HI guys, I may have a head gasket problem,what do you guys think, here's the symptoms :
uses abit of coolant, no obvious leeks(cooling system), a wee bit of froth/bubbles appear at the radiator neck when the bikes rpms raised up abit(2500,3000 rpm) from idle, sludgy grey/white/clearish matter around the radiator cap seal and spring.
The oil looks good though.
thanks
osti33
posted January 14, 2005 06:56 PM
Sounds like a head gasket to me. I had the same symptoms except for the sludge when I had my head gasket go out.
posted January 14, 2005 09:58 PM
let it idle on the stand until the fan comes on, then look in the sight of the overflow tank. If you see bubbles, you have head gasket troubles; at least i did...
phantom
posted January 15, 2005 11:22 AM
thanks guys
0.20866107940674 seconds processing time
