BIKELAND > FORUMS > ZX12R ZONE.com > Thread: OT: Carb prollems? NEW TOPIC NEW POLL POST REPLY
jonwright
posted October 01, 2004 06:03 AM
OT: Carb prollems?
So this isn't a 12R question. Sue me.
There are a LOT of good gear heads on this board.
Here's the thing with my little R6:
She had trouble cranking - thought it was the battery. Worked okay.
Now she fires up and runs okay. I can do my hot lap to go to the grid, then when I pull up to the grid it dies. I pull in the clutch and she won't start - turns over but doesn't catch.
Go to the pits, let it sit for a little bit. Fires right the hell up.
Seems she goes to hell when the engine warms up.
A theory is the pilot jet in the carb is hosed up. When the bike gets hot it leans out.
What's the thoughts of the peanut gallery?
EastBayDave
posted October 02, 2004 05:04 AM
fuel tank vent plugged? Had the same problem on an old KZ back when I raced eon's ago...finally traced it to plugged vent. When that happens open gas cap....if you hear a "woosh"...you found the problem.
OR, possibly the fuel tap vacumn diaphram not working? Allows just enough gas in to get you those couple miles around the 1 lap, then bingo- out of gas. Try running it on "prime" (to bypass the vacumn diaphram), & also make sure the vacumn lines to the petcock are hooked up (had the carbs off lately?)
anyway...grasping at straws here...those two were a couple of related problems I had to the symptoms you discribe...hope this helps...
EBD
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
0.22352194786072 seconds processing time
