BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Murphy Blows! ......so does that damn FI light! NEW TOPIC NEW POLL POST REPLY
BA
posted September 28, 2004 05:01 PM
...my little saga continues and I swear Mr. Murphy is looking over my shoulder.
The cam timing on my engine is fixed,....it was good on the intake, but 4-5 degrees off on the exhaust. (retarded)
The shims are all corrected.
Things are buttoned down (up?) and I figure I'm ready for some compression and leakdown tests before firing it up...again.
It won't crank over! Som'bitch. My damn FI light is on as soon as I turn the key on.
That's not normal is it? I don't recall the FI light being on just with a turn of the key. I thought it was just the oil light that came on.
So, I'm double checking things. My only place I have concern is the oil pressure switch. The end is like a clip right? Well, one side of that clip broke off so I'm wondering if this is the cause of the FI light or the "no crank" situation.
I thought I had it covered by sandwiching it between two very thin washers but that didn't seem to change anything.
Any thoughts out there? This thing just cranked a few weeks ago! All connections seem to be made, battery is good, gauges swing, horn honks, absolutely no cranky though. FI light ON.
motorcycleboy
posted September 28, 2004 05:25 PM
It won't crank or it won't fire?
Are you saying the starter won't even turn over or it turns over but the motor won't fire?
BA
HAHAHAHAHA !!!!
Ok, never mind me, I went ahead and took it out of gear. lol!
Canadamaxxer
posted September 28, 2004 06:04 PM
D'oh!!!!
BA
posted September 28, 2004 07:11 PM
For those who want to follow along, Mr. Murphy DID show up after-all tonight.
Compression check, butt COLD!
1 - 125psi
2 - 115psi
3 - 130psi
4 - 120psi
Not what I was looking for, but, let's move on.
Leakdown Test, also butt cold!
4 - 25% hmmm. a bit through the crankcase
3 - 10% deserves a second check but, my adapter was contankerous.
1 - 19% ok, I can live with this on a cold engine.
2 - 50% Checked, re-checked, re-checked and re-checked again. it's 50%.
sounds like mostly intake noise.
sure would suck to have to take the head off and have it checked. {insert insanely mad, ballistic little emoticon here}
Guess I'll go quadruple check the valve clearance on #2 just to be sure.
Widowmaker
posted September 28, 2004 08:46 PM
LOL, I did something stupid kinda like that. Im at a friends house and I decide to leave, the bike is 1 week old goto start it nothing lights are on .
so my buddies start pushing me so I can jump start it they push me up and down the street around 5 times (nothing wtf) so I bang on the starter switch a few times bam starts right up fucken short in the starter switch right, well about a month goes by and it fucken bike does it again.
so I goto bang on the starter switch and notice the kill engine switch clicked well I rarley use it and from hitting on the starter that night my buddies pushed me it switched the cut off switch back to run talking about stupid.
ninja12
posted September 29, 2004 04:58 AM
don't know why the valves stick when the head sits up, but i have had luck tapping the valve bucket while the leak down pressure is still on and cams out . makes a popping sound and the pressure will come back.
I almost pulled my head after i put the hd springs in, for the same thing.
NOW i always do my leakdown BEFORE i put the cams in.
0.22106003761292 seconds processing time
